Steering Rack Shims
Elan Plus 2
I have what looks like a Lotus Replacement Frame that I have been getting ready to drop the body back on to.
Everything is ready to go for this weekends body drop - BUT - I am not sure about the steering rack shims.
I do not see any markings on the frame indicating shim thickness.
This is one of the things I'd like to address while everything is right
there in the open for me to work on.
The Shop manual just says put the shims back in based on the frame
stampings.
Without the full body weight it does not seem like I can determine the shims needed prior to setting.
I guess it is possible that no shims are needed with the replacement frame
(bought second hand so I can't just ask).
What are the collective words of wisdom - bolt it up now without shims and
resolve when everything else is done?
Briggs Pletcher
stampings.
Briggs Pletcher
- Briggs1
My twopenneth
I don't think you can set the "bump-steer" shims etc without the body on and car loaded as normal as the ride height will not be right.....I am open to differences of opinion on this but the bump steer is a deviation from normal ride height geometry up and down.....
Flood gates open...
Flood gates open...
There is at least one long thread concerning bump steer, with the usual contradictory information. But you can simply install shims as needed to bring the rack mount surface to exactly the right height relative to the wishbone pivot spindles. If you had the marks on the frame, installing shims of the specified thickness would position the rack where God and Colin (is there a difference?) intended it to go, and the bump steer will be correct.
The other approach is to go through the whole bump steer procedure to determine shim thickness and the rest of the suspension settings. You probably will want to review that bump steer thread first and decide if you want to deal with all that hoo-rah. I certainly didn't.
There should be a dimensioned drawing that provides the distance between the lower spindles and the rack mount surface. Brian Buckland's (Baby) Elan book shows how to measure from the top spindles (and provides the magic dimension), but you need the body off in order to do this. That's how I determined which shims to use.
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
As a very good starting point go to the workshop manual and find the page with the front end dimensions.
It should list the lower control arm mounting bolt to rack bottom face dimension.
add sihims until the bottom of your rack is this distance from the center of the lower control arm mounting bolt.
This is what the factory shims would be.
Now whether or not this is the best for bump steer is a totally different discussion.
If you want the best for bump steer you can do it without loading the car since it is best done without shock and spring so you can move the arm through it's travel, but the chassis needs to be level.
Rob
Rob
- Rob_LaMoreaux
On a related topic, I recently took delivery of a new TTR racing chassis, which I had powder coated gloss black. I don't see any stampongs where the proper shims are defined. Could it be that fabrication is so good that the rack can simply be bolted on?
Bill
Bill
- bill308
Been following this thread with interest.
Curing bump steer is not done by simply placing
a couple of shims under the steering rack, (Regardles
of what was done at the lotus factory) it requires
many hours of working with measuring gauges and
creating a bump steer graph while the suspension
is operated throughout it's full movement from full
droop to full bump.
The links below will provide excellent description
and data of how to go about curing the problem
of bump steer.
Bump Steer: Lotus Seven Club.
http://7faq.com/owbase/ow.asp?BumpStee
Bump Steer.
http://www.longacreracing.com/articles/art.asp?ARTID=13
Tech Article #9 - BUMP STEER GAUGE INSTRUCTIONS
http://www.irvansmith.com/scart/article ... cles_id=11
Good luck
Col.
droop to full bump.
of bump steer.
Bump Steer.
Good luck
Col.
- ceejay
Well I couldn't get into the first one but the second says....
"Set the car at ride height."....and if yours is at ride height with the body off etc. then O.K.....but mine isn't....
john.p.clegg wrote:Well I couldn't get into the first one ....
Hi John
Try
http://7faq.com/owbase/ow.asp?BumpSteer
If you read the link, you may see its missing the "r" in BumpSteer
sometimes you have to think about the links and what people were trying to say when the links don't open.
Gary
Gary
Many thanks
Once again.....resting the chassis on blocks at its normal ride height....
It seems that bumpsteer uses normal ride height as the mean,and equates the deflection either side of this to negate bumpsteer.
If your car is as per factory spec.(springs weight etc.etc) then O.K. but any change of weight (driver,passenger,fuel,spring length,strength etc.) will need the shims re-calculating as per the examples...
Many thanks
Briggs, you can set up the bump steer shims with the assembled chassis, complete with front suspension and steering, without the body.
Basically you will need to remove the damper/spring assembly, rest the front cross member on blocks at approximately the correct ride height and then stroke each front suspension up and down. This can be done with a small trolley jack etc. Lock the steering in the straight ahead position.
As the suspension moves into bump and rebound, the steering knuckle will change angle slightly. This is the definition of bump steer. You will need to measure the change in the angle with a dedicated bump steer gauge (eg checkout demon tweaks website) or use a mirror and laser to measure the change in angle. Refer to the many postings on this site.
Gerry
Gerry
- gerrym
This may be of help, its on the Elan.net site
http://www.lotuselan.net/publish/steeri ... hims.shtml
john.p.clegg wrote:Once again.....resting the chassis on blocks at its normal ride height....
John, I don't think it is critical to have the car at 'normal ride height'.
The aim is to eliminate/minimise bump steer throughout the WHOLE suspension travel.
I did this on my +2 (which used to veer alarmingly across the road, one way under braking and the other under acceleration ) using a bent piece metal as a pointer clamped to the trunnion with mole grips .
I set it to point to some part of the upright (I forget exactly where) then, with the steering fixed, I watched whether the pointer remained pointing at the same part i.e. see if the upright rotates relative to the trunnion as the suspension moves. After adjusting the shim thicknesses several times and rechecking each side, it is now much better .
Note that adding shims to one side will tilt the rack & change things slightly on the other side...
Matthew
- ppnelan
