Steering rack shims
When shimming the steering rack on an Elan does the 2.19" (55.6 mm) dimension apply to the distance from the centreline of the front lower wishbone stud to the base of the rack OR to the centreline of the rack?
John Larkin
John Larkin
1967 S3SE FHC, 1974 Rover P6B, 1949 Lancia Aprilia
- John Larkin
lotusfan wrote:Its reasonably easy to measure with a long straight edge across the pins and a vernier height gauge.
Reasonably easy if the body and the top front arms are off. Otherwise you need to come up from the bottom studs. I will defer to others on your original question - my guess is that the measurement is to the top of the shim stack, not the base or centerline of the rack, but I am not sure.
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
http://www.flickr.com/photos/16638375@N03/2420913100/
Here is how I went about it
- neilsjuke
