Steering Rack Mounting
Does anyone know how to arrive at the required thickness of shims under the rack mounts ? Workshop manual says chassis is stamped ex factory - my shims are extremely rusty and the Lotus replacement chassis does not appear to be stamped - any ideas ?
- oldelanman
There are lots of threads on here from the past years re.setting the shims for bump steer,the workshop manual is a good place to start
Thanks John and Barney for steering me in the right direction on this topic. Having just discovered the site I did not appreciate the volume of information already available!
- oldelanman
I'd suggest a look at this thread which talks about using a laser pointer and mirror to check bump steer. http://www.lotuselan.net/forums/viewtopic.php?t=2632 and check the web page mentioned www.advancedracing.com for a picture of the setup on the disc. Didn't use anything fancy like the setup in the link. Just a piece of mirror taped to the disc and pointer clamped to a stepladder as described in the thread. I've used this method and it worked well.
Steve.
Steve.
'71 Sprint DHC
steve71 - First Gear
