Steering joint
PostPost by: Robbie693 » Thu Aug 09, 2007 11:19 am
My MOT tester gave me an advisory on play in the joint between the rack and the column. I have found a guy selling them for Spitfire, Herald and GT6.
Are they the same as those for a Plus 2?
Robbie693
PostPost by: ppnelan » Thu Aug 09, 2007 4:04 pm
Yes, I believe so. How much can you get them for?
:arrow: Matthew
ppnelan
PostPost by: Robbie693 » Thu Aug 09, 2007 4:22 pm
Thanks Matthew.
It's ?12.50, which is half the price of the usual suspects.
Robbie693
PostPost by: fatboyoz » Fri Aug 10, 2007 4:48 am
Robbie693 wrote:My MOT tester gave me an advisory on play in the joint between the rack and the column. I have found a guy selling them for Spitfire, Herald and GT6.
Robbie,
How about these parts "SPF1179K Front Steering Coupling Bushing" from this website http://www.superpro.com.au/superpro.html The "Where to buy" link, in the middle of the page, will show you the UK distributor.
Colin.
fatboyoz
PostPost by: Stuart+2 » Sat Aug 11, 2007 2:54 am
Hi Robbie
I recently replaced the original coupling on my +2 with a UJ from Spyder -brilliant result but the UJ was slightly longer by a centimetre or 2.
It just meant that I had to move the outer column towards the driver by the additional length to meet the steering wheel at its new location.
If you can find a UJ that is the same length as the original it will be a lot easier.
Stuart - Sydney
1968 +2 50/1035
Stuart+2
PostPost by: Robbie693 » Sun Aug 12, 2007 10:03 am
I ordered a coupling - not arrived yet.
Thanks for the link Colin but as mine is a bit grotty anyway I decided to replace the whole thing.
Stuart, the guy I bought it off also does an uprated solid joint which is supposed to be a Group 4 rally part for a MK1 Escort. This also is a bit longer than the original. The steering wheel is a bit close anyway for my shape so I bought an original design one (Looks like it anyway!) to hopefully keep the wheel in the same place. Fingers crossed.
Link to the original style one :
http://cgi.ebay.co.uk/TRIUMPH-Spitfire-GT6-Herald-STEERING-JOINT-COUPLING_W0QQitemZ190139848475QQihZ009QQcategoryZ27383QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and the uprated type:
http://cgi.ebay.co.uk/TRIUMPH-Spitfire-Herald-GT6-STEERING-JOINT-Upgrade_W0QQitemZ190137263531QQihZ009QQcategoryZ27383QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Robbie693
PostPost by: rgh0 » Sun Aug 12, 2007 11:19 am
Unless you have an early plus 2 with the Ford shaft you can accomodate a longer U joint in an Elan or Plus 2 by adjusting the sliding coupling in the middle of the Triumph shaft so the steering wheel does not have to move.
