Steering Rack
Mine kick over a bit with original rubber bushes but they seem to clamp the rack OK. I haven't tried polys
Sorry, couldn't resist adding; have you seen your doctor about this!!!
"He's not the messiah, he's a very naughty boy"
Monty Python's The Life Of Brian,best film ever.
- lotusanglia1965
If you put a little shim under it don't you alter the bump steer(steering rack height) setting?
Sorry, should have been more clear. The shims that control the rack height are already there but they aren't wide enough to go under the little 'claw arms' , so to speak, and the clamp seems to want to cock down where the claw arms are. I shimmed under the claw arms to keep the mount from cocking. Hope that helps.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
