Heater suddenly blows cold, then corrects itself
Evening all. I have some curious behaviour on my Sprint and looking for some guidance.
For context, a few months ago I had to send the water temp gauge off for refurbishment, which meant a partial drain of the coolant. When I got it back, coolant replenished and after a few trips the radiator cap decided to break its seal and piss water out. New cap later, coolant topped up again and after a few trips the Otter switch stopped working. New Otter switch ordered and fitted, coolant topped up again.
Note whenever I refill the coolant it’s always with the car jacked at the front, heater open, and squeezing top hose. Made sure all water up to the radiator filler neck.
So to get to the current situation. I notice the temperature gauge runs in the low 80s on quiet journeys - pops up to 90 in traffic and drops down when the electric fan kicks in.
But 2 weeks ago I included a Motorway section on my route and the temperature climbed to early 90s even on a steady stretch. However at the same time any hot air coming through the heater became stone cold. I was concerned about either an air lock; water pump issues; thermostat issues or heater valve issues. I fiddled with the heater control whilst driving and normality returned - hot air out the heater and the temperature gauge dropped (in 5 degree chunks). There was no sign of any water loss when I had arrived home.
Went out again today, and had the same behaviour - which commenced at exactly the same point on the same road ! This time I didn’t fiddle with the heater control and although the temp gauge level stabilised at about 92, there was still cold air through the heater. It stayed cold for a number of miles until I was nearly home, and lo and behold, heat was restored all by itself.
I’ve probably done about 10 trips since the last water top up so I would have thought any air would have worked it’s way out of the system through the recuperation bottle cycles by now. But is what I’m experiencing an airlock ? Or, has anyone experienced issues with the heater valve that shows the same behaviour ? I could imagine a failure of the valve that would leave it either full hot or cold, but not intermittently not working and then starting again.
Thoughts welcome.
Thoughts welcome.
'72 Sprint
'72 Sprint
- richardcox_lotus
Sounds like an airlock, but try without jacking the car up as this may be causing trapped air to rise to the top of the heater matrix and not clearing. Remove the radiator cap, shut off the heater valve and disconnect the heater hose at that point, lift the hose in a vertical direction and using a funnel of some sort try filling the tube with water. You can watch what is happening via the radiator filler hole, but remember to lock off the overflow tube. You can also try blowing down the tube to free any trapped air.
A further variation is to hold the heater hose below the level of the rad and heater valve and blow into the radiator, remembering to catch the water in a bucket or else wet feet. The final alternative is to try and find someone or your local friendly garage that has the kit used to pressurise the system when looking for leaks.
Some engines seem to be worse than others for this problem, then of course there are those that are no trouble at all (but I know you perhaps don.t want to hear that right now)
Best of luck
Tony
Best of luck
Tony
- tonyabacus
Hi Richard
I would say you need a new Heater Valve.
I think the Diaphragm in old one has crumbled.
Do you have a recuperator Bottle to the small overflow pipe next to the Rad Cap.
Also is the Rad Cap correct with 2 Valves.
- alan.barker
Hi Richard
I had a similar problem where the heater stopped working then started working etc etc.Look at the post on heater blows cold.
My fault was the heater valve.I took it off and piped direct via a good quality ball valve.This cured the problem but I have to pop the bonnet to turn on off.A but a small point really. I have a dhc I have the heater on all the time except for extreme hot weather.The valves fitted are not a well engineered product and can cause a lot of problems
G
G
- MACCA.GLM
Hi all. Thanks for the replies and not sure how I missed the ones from Tony and Alan at the time.
The situation is that it has partly corrected itself. I typically get heat out the heater now, and the engine doesn’t run too hot. In answer to Alan’s query, yes I have the recuperation bottle, and yes I have a radiator cap with 2x seals.
However, although I do get consistent heat, it’s not very hot, and MACCA I have been reading your thread on the heater valve and have sort of come to the same conclusion, that mine is no longer operating as efficiently as it should.
I can live with it for now, but when I have to do something that necessitates removal of an engine mount, I shall do so, as I can then move the engine out of the way to replace the valve.
Thanks for the comments.
'72 Sprint
'72 Sprint
- richardcox_lotus
richardcox_lotus wrote: when I have to do something that necessitates removal of an engine mount, I shall do so, as I can then move the engine out of the way to replace the valve.
Regards Richard
Richard, you can change the internals of the valve without disconnecting the engine mount, you have to drill or cut out the rivet off, rotate the outer cover then disassembly the internals, change with new internal from a new valve you have disassembled and reassemble.
If the inside of the valve is badly corroded then engine mount will probably have to be disconnected.
Picture shows where I changed the rivet with a small bolt nut.
