Heater Connection - Temp Sender Unit?
PostPost by: hastu » Fri Apr 07, 2023 7:17 am
Once again i need some help for my out of the box project
On may +2 S130 beside the Thermostat House there are 2 Connections.
The left is the angled Heater Connection. This Connector for the heater hoose has a Diameter of 13mm.
The Rest of the Heater Parts, the Radioator in the Heater Box has 16mm Connectors. Is that right, do i need a Adaptor to connect the Heater Hose für the 16mm Connector on the 13mm Connector
On the right side of the Picture seems to be a kind of sender Unit., butt there is no Connection to fit a wire on it.
Maybe this Part was broken away. Dooes anybody know which part it really is
regards
K640_IMG_4069.JPG and
Connector at Thermostat House
Hanspeter
Elan +2 S130 1971 Pistachio Lime Green
hastu
PostPost by: HCA » Fri Apr 07, 2023 9:23 am
I have not measured to diameters of the heater connections, but would think that a decent quality hose would cope with a 3mm difference…
The sender on the right is for your temp gauge. If the connection is broken, you will need a new one.
Hal Adams
Evora SR
Elan +2
HCA
PostPost by: TBG » Fri Apr 07, 2023 12:28 pm
That hose in the picture looks perisously close to the exhaust! D
TBG
PostPost by: mbell » Fri Apr 07, 2023 2:06 pm
For some reason lotus fitted 1/2" fittings on the engine and used 5/8" hose and heater connections.
I used a short section of 1/2" inner 5/8" outer pvc (I think) hose over the engine connections so I didn't have to clamp the 5/8" hose down so much.
PostPost by: The Veg » Sun Apr 09, 2023 2:16 pm
mbell wrote:For some reason lotus fitted 1/2" fittings on the engine and used 5/8" hose and heater connections.
Ford at one end of the hose and Smiths at the other end?
Also, Lotus Marques have a spigot-fitting for the water pump that solves this problem.
2012 BMW R1200GS
The Veg
PostPost by: mbell » Sun Apr 09, 2023 3:06 pm
The Veg wrote:Ford at one end of the hose and Smiths at the other end?
Heater hoses go into lotus designed and manufactured components on the engine. For some reason lotus bought 1/2" rather than 5/8" fittings.
PostPost by: The Veg » Sun Apr 09, 2023 5:10 pm
Of course; I forgot that one detail. What does occur to me though is that the spigot appears to be a standard brass plumbing fitting though, and while I don't know how it works in the UK, but in my observation for some reason over here fittings mostly stick to either halves & quarters OR eighths, or at least not translate halves and quarters to the nearest eighth. But a machinist could certainly make something like that and I think that's what LM had done. I certainly couldn't find such a fitting at any plumbing supply merchant.
2012 BMW R1200GS
The Veg
PostPost by: mbell » Sun Apr 09, 2023 11:03 pm
Yeah they standard UK plumbing fittings, BSP(P). But like here you can get fittings with different barb sizes for the same thread size. Would find it surprising if the right fitting wasn't commonly available at the time.
