1968 Lotus Elan S4 heater
My 1968 Lotus Elan S4 has no heater so i plan to fit a Jegs 70602 auxiliary heater, ive purchased the control valve to connect the outgoing water for the heater, BUT where does the outgoing hot water return to ??? to complete the loop. any help would be gladly received,
Norman
Norman
- UNICORN
A fitting on the right side near the front of the engine near the water pump.
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle - Fourth Gear
There should be a fitting in into the coolant return line from the radiator in the front cover, this points to the rear of the car.
In theory the fitting might have been removed and a plug fitted instead or just blocked off via a piece of hose.
- mbell
