Heater
PostPost by: Quattro123 » Sat Oct 31, 2020 3:39 pm
Engine is at normal operating temperature
Interior heating warm just
Windscreen demist stone cold
Quattro123
New-tral
PostPost by: john.p.clegg » Sat Oct 31, 2020 3:46 pm
airlock
flaps positioning
Flap seals
John ;-)
PostPost by: RobMc » Sat Oct 31, 2020 9:36 pm
I agree with John.
I recently had the same problem with my heater after firing the engine up for the first time in 20 years. The engine was up to temperature but nothing from the heater. It turned out to be an air lock and the heater now nearly takes the skin off your legs when up to temp.
The only other possibilities might be a blockage or a faulty heater valve?
Rob.
Rob
1969 S4 Elan
RobMc
New-tral
PostPost by: Quattro123 » Sun Nov 01, 2020 4:33 pm
Heater hose in hot
Heater hose out warm
But air still cold onto windscreen
Quattro123
New-tral
PostPost by: john.p.clegg » Sun Nov 01, 2020 5:35 pm
Flaps positioning
Flap seals
John ;-)
PostPost by: smo17003 » Sun Nov 01, 2020 8:19 pm
If the sponge seal around the heater core has disintegrated over time them the airflow into the heater box will take the easiest route i.e. around the core and not through it.
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: john.p.clegg » Sun Nov 01, 2020 9:21 pm
...not forgetting the rubber/neoprene seals on the flap edges..
John ;-)
PostPost by: alan.barker » Mon Nov 02, 2020 7:59 am
Is it an Elan or Plus 2.
Different Systems.
PostPost by: Quattro123 » Mon Nov 02, 2020 7:35 pm
Plus 2
Quattro123
New-tral
PostPost by: alan.barker » Tue Nov 03, 2020 6:19 am
I think if you take both Heater hoses off at the Engine end. Then flush through using Garden hose pipe. Reconnect low Hose to Engine near Dissy. Fill other Hose so Heater is full. Fit Hose to Thermostat Housing.
Run Engine.
I had this problem before and was the fix.
Good luck
PostPost by: Quattro123 » Tue Nov 03, 2020 6:10 pm
OK great will give it a try hanks
Bart
Quattro123
New-tral
PostPost by: Bigbaldybloke » Fri Nov 06, 2020 12:13 am
Years ago mine was similar, flushing it out was the cure, got brown lumps coming out like small Maltesers! Worked fine after that!
