Elan Fan Heater Motor Exploded Diagram
PostPost by: Mazzini » Wed Jan 02, 2019 11:57 am
Anybody got an exploded diagram? Failing that do you know of a company that can rebuild the unit?
Thanks.
PostPost by: Lotus14S2 » Fri Jan 04, 2019 8:09 pm
I am not sure but I don't think the motor is rebuildable..
This is a standard Smiths part, and you might look at suppliers of Smiths parts, particularly those that supply parts for Triumph or maybe MG. I think the heater is the same as a Triumph Spitfire, but taking photos and sending them to a seller should give you all the information you need.
I hope this helps.
Lotus14S2
PostPost by: wotsisname » Fri Jan 04, 2019 8:23 pm
They're a fairly standard design and not overly complex.. not sure how easy it is to get parts (brushes, etc). If you do dismantle you should clean the shaft before splitting the case so that the bronze bush remains in the case and not stuck to the shaft..
1968 Elan plus 2 - project
2000 Elise S1 - Sold
wotsisname
PostPost by: Mazzini » Fri Jan 04, 2019 8:32 pm
Thanks fellas, it doesn't look complicated, but there are quite a few washers and I'd like to get the sequence right. I'm sure common sense will prevail...or I'll see what my friendly sparky is up to this weekend :-)
PostPost by: benymazz » Sat Jan 05, 2019 1:34 am
I seem to recall reading somewhere that it's the same unit that was in the MGB, but I could be wrong.
1965 S2 26/4623
benymazz
PostPost by: gjz30075 » Sat Jan 05, 2019 10:12 am
I don't know if it's any different on a +2, but The Veg just went through this and found a modern
motor as a replacement. Can't find the thread at the moment.....
Ah, here it is
lotus-electrical-f38/fan-control-questions-t42899.html
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
