heater problem
To activate the heater in my S4 FHC - do I have to pull or to push the heater knob? Anyway, I have the impression that the heating system is working constantly - ist very hot inside the cabin... the dashboard ist in total very hot too...
I add a picture from the heating valve - is this position closed or open??
Thank you very much for your help!
- Giallo77
it's opened, it's a valve and the closing part is now away from the opening. You also can see that the actuation lever, which is underneath, is like it's in a "pulled" position, which normally corresponds to the dash knon away from the dash (closed is knob against the dash).
S4SE 36/8198
nmauduit - Coveted Fifth Gear
If I push my heater closed, it slowly re-opens which I wonder is down to water pressure. Any suggestions as to how I keep it fixed in position - regardless of what that position is ?
'72 Sprint
'72 Sprint
- richardcox_lotus
Is the knob supposed to twist lock like the choke we never use!?
See here for mixed views
lotus-twincam-f39/heater-valve-question-t15029-15.html
- MarkDa
MarkDa wrote:Is the knob supposed to twist lock like the choke we never use!?
Yes a twist is supposed to lock the position of the knob stem.
I had the same problem with the temperature control knob creeping out from the dash on my S2. I first thought the fact that the length of the original wire was too short. So, I tried several mods to the knobs shaft, first by replacing the original wire with a longer one, when that didn't work, I then tried increasing the diameter of the wire that operates the water valve. None of these changes seemed to fix the problem, as it continued to creep out, and the increased wire diameter just made it harder to push in and pull out. I know have a large collection of different diameters of music wire. What I found was the valve needed a bit of tweaking in the alignment of the wire to the operating lever. Most of the replacement water valves do not align correctly. I had replaced the valve when the original diaphragm ruptured while in the middle of no where. By adjusting the alignment , I was able to reduce the music wire diameter and the knob no longer creeps out.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
