S3 pre airflow coupe,,,,sunvisors?
PostPost by: gjz30075 » Tue Nov 28, 2017 3:22 pm
My car did not come with sunvisors and I saw the Service Parts list (pub. 1976) shows
sunvisors began on car #5811. Mines 5727. However, the provision for sun visors
are there. No holes in the headline but I'm sure at some point, its been replaced.
No coat hook either.
So, should the car have sun visors or not?
dsc00189.jpg and
dsc00188.jpg and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: donselan » Tue Nov 28, 2017 6:53 pm
Hi Greg,
My pre-air flow coupe 5607 has sun visors and coat hooks. The only problem is that the sun visors interfere with the rearview mirror when lowered.
Don
Don Fysh
S3 Elan FHC 36/5607
S3 Elan DHC 45/6646
donselan
First Gear
First Gear
PostPost by: Bushwacker » Fri Dec 08, 2017 3:41 pm
Hi Greg,
Congratulations on getting a pre-airflow coupe! What are your plans with it? Restore to the same high level of your S4 I imagine. ( I met you at LOG 34? in Asheville )
I have 36/5357 pre-airflow coupe. It has sun visors, though I don't have a headliner. Removed by PO for
racing set-up. I think the texture pattern of your headliner is not the original style. ( Other members can confirm or dispute ) I will be interested to follow along in your restoration as I have just begun the tear down of mine.
Good luck.
Eric Johnson
Life's too short to drive boring cars!
'66 S3 Elan Coupe'
Bushwacker
First Gear
First Gear
PostPost by: nmauduit » Fri Dec 08, 2017 5:57 pm
gjz30075 wrote:No coat hook either.
If of any use, here is a photo of the original location of the coat hooks on my 1968 Federal S4se, on the cardboard pieces on which the coat hooks (and interior lamps) were held which replaced by the upholstery man - I'll put them back next time I redo the headliner, and that will be correct "confetti" style this time....
p1040756.jpg and
1968 Federal S4se rear post with coat hook location
S4SE 36/8198
PostPost by: gjz30075 » Fri Dec 08, 2017 6:02 pm
Hi nmauduit. My headliner is also 'non' confetti and when I pull off the sail panels, hopefully there'll
be tell tale holes for my coat hook
Thanks!
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: nmauduit » Fri Dec 08, 2017 7:12 pm
gjz30075 wrote:Hi nmauduit. My headliner is also 'non' confetti and when I pull off the sail panels, hopefully there'll
Thanks!
Hi Greg
it may be difficult to zoom enough on the photo once downloaded on the forum but the material still attached to my original cards is "confetti" - long story, but I eventually found a supplier who offers confetti material that is pretty close to the original, actually 2 versions, one with the confettis a bit smaller, the other a bit bigger (the one I would use) : SMS auto Fabrics 350 south redwood st. Canby OR 97013.
S4SE 36/8198
PostPost by: gjz30075 » Fri Dec 08, 2017 7:51 pm
Great, thanks!
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
