S3 Heater valve part missing
PostPost by: CG901 » Sat Aug 26, 2017 2:14 am
While installing the twin cam in my s3 coupe, I noticed the bolt that holds the temperature cable in the control unit on the head was missing.
I have checked all the parts sources but it seems being such a miscellaneous part, it is not stocked.
Can anybody tell me where to source or how to fabricate a suitable substitute? Here is a diagram of the bolt with green arrow. Thank you.
missing-cable-bolt.jpg and
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901
PostPost by: Concrete-crusher » Sat Aug 26, 2017 9:03 am
Try looking on ebay under pinch bolts as used on bike brakes
Concrete-crusher
PostPost by: lotusfan » Sat Aug 26, 2017 10:18 am
If you just need the screw it is 10-32 UNF but if you need the solderless nipple as well e-bay or a bike shop as Steve said is the way to go.
72 Sprint DHC
lotusfan
PostPost by: Mazzini » Sat Aug 26, 2017 10:54 am
PostPost by: CG901 » Sat Aug 26, 2017 5:28 pm
Thank you all. I have I one on order!
CG901
PostPost by: billwill » Sat Aug 26, 2017 6:07 pm
It looks as if a bicycle brake nipple would do the job.
Users browsing this forum: No registered users and 41 guests
