MacGregor and Rubber
PostPost by: Tahoe » Wed Jan 14, 2015 6:49 pm
Okay, I need rubber parts and I've emailed MacGregor in Canada 3 times, and tried calling with no response. I did talk to him once, and he was very nice, but said his prices were very out of date and they don't take credit cards. I was supposed to send him a list, which I did, but no response on current prices or shipping.
I'm done with trying, and would like suggestions on the best alternative here in USA. Does Dave Bean have the seals? I haven't called them yet, only because my last dealing with ordering hardtop seals from them. They had what I needed but good God they were expensive! Must be some sort of proprietary rubber :wink:
I'm also okay with ordering from a supplier overseas so if anyone has a suggestion for getting the correct rubber seals (doors, trunk, windshield frame to body, etc.) I'd appreciate it. I haven't tried JAE yet either.
Will wait for any response before calling Bean or JAE.
Tahoe
PostPost by: collins_dan » Wed Jan 14, 2015 9:58 pm
I bought some last year from MacGregor and some from Ray at rdent.com. The shop that installed the windshield didn't like the one from MacGregor as it needs to be mitered and wanted one that was one piece, which Ray carries. The door seals from MacGregor are the bulb type and definitely push the doors out more than the original. Ray has the flap type, which I think might be better. I am sure Ray carries the trunk seals, so I would give Ray a call. Dan
collins_dan
PostPost by: Tahoe » Wed Jan 14, 2015 10:55 pm
Thanks Dan I will. The most important ones I need are the window fuzzy strips (both sides of window) and the window channel U shaped strips. I do need the others as well. I would think the fuzzy stuff is pretty generic but I'm not sure. If it is I guess you can get them almost anywhere.
Tahoe
PostPost by: Famous Frank » Thu Jan 15, 2015 2:27 am
Russ, I carry the u-shaped fuzzys for the door windows. The front one is flexible and the rear is rigid. They are a little snug on the glass when new. I've thinned out the fuzzy by running a screw driver blade up and down in the u shaped channel. I've sold a bunch of them without complaints. $30 a pair front and $30 a pair rear. RD has some good fuzzys that go along the top of the door inside and outside.
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank
PostPost by: Tahoe » Thu Jan 15, 2015 3:13 am
Frank,
PM sent
Tahoe
PostPost by: collins_dan » Fri Jan 16, 2015 2:11 pm
Make sure and get a new set up clips to hold the fuzzies in. The old will be rusted or break on removal. I think Ray has them, or Frank might, or I have some left over. Also, make sure to get new clips for reattaching the rods that control the door lock. Same problem. They are the hardest part of the job. Good Luck. Dan
collins_dan
PostPost by: nomad » Fri Jan 16, 2015 3:01 pm
I need all the same so thanks much for the post. Also wondering if the seal that goes around the back of the 26 hardtop is available? If I can get the hardtop seal's I may try to restore mine.
Kurt
26/3754
nomad
PostPost by: bill308 » Sat Jan 17, 2015 2:58 am
Kurt,
Kelvedon has the hard top to rear deck seal. See RACEHTS01 here:
http://www.kelsport.net/parts/products. ... ctionID=23
Bill
bill308
PostPost by: nomad » Sat Jan 17, 2015 1:51 pm
Thanks much Bill....looks like what they offer will fill the bill!
Kurt.
nomad
PostPost by: Tahoe » Sat Jan 17, 2015 4:47 pm
Thanks Dan for the clip information. I have no fuzzy clips at all so will order them.
Nomad,
Bean has the hardtop seals as well. The rear seal he sells is exactly the same as the front hardtop to windshield frame seal. Now I don't know what is correct or not, but they do seem to fit (not installed yet). The rear glass seal on the hardtop is the same as the rear coupe' seal.
Tahoe
PostPost by: nomad » Sun Jan 18, 2015 2:08 pm
Thanks Russ!
Kurt.
nomad
PostPost by: bill308 » Sun Jan 18, 2015 11:16 pm
Hi Russ.
I was unaware there is a seal between the front edge of the hardtop and the top of the windshield frame. Do you have a part number or other reference for this?
Bill
bill308
PostPost by: jk952 » Mon Jan 19, 2015 12:47 am
Russ,
Mcgregor typically shows up at the local shows, is located in Dundas Ont. last I knew.
The rear trunk seal he has is not correct for an S2 but (I do not want to criticize, only inform), I am not sure of any source for it but would be interested if there is one.
Looks like, in cross section, an "n" with an "O" touching the side of the "n" but no reinforcing, just soft rubber. Unfortunately I discarded my beat up original, the reinforced one warps the trunk lid as others have identified on this site; I tried cutting and tweaking to no avail. He does have the correct S2 door seals, again no reinforcement, (and the trim bit for the fiberglass edge) although admittedly I have not yet fitted the ones I purchased a few years ago(!) (which hasn't been an issue, my doors fit very close.).....
Jack
jk952
PostPost by: bill308 » Tue Jan 20, 2015 3:51 pm
I don't think Lotus ever got all the weather seals right on the Elan, and certainly not on the type 26. The door seals are poor and the trunk seal is probably worse. The MacGregor trunk seal is simple, symmetrical, and effective, a much better solution IMHO, but not original.
Bill
bill308
PostPost by: jk952 » Tue Jan 20, 2015 5:20 pm
Thanks Bill, maybe he mistakenly gave me the wrong one, do you have a pict?
The reinforcement one sits up too high, even after cutting the rubber a bit to make it more flexible. Or the fiberglass is somehow different. .. :D
Jack
jk952
Next
