Heater valve clearance?
• Page 1 of 4 • 1, 2, 3, 4
After installing the engine recently, I've noticed how the clearance of the underside of the Heater valve to the Fibreglass body is almost nil ? ( and I'm worried about it !)
Checking for photo's in the various publications, does not clearly show how much gap is required either.
I'm worried that flex in the engine mounts and vibration from the engine may cause the Heater valve to rub against the body, and cause damage to both ?
Further more, I thought the main engine compartment wiring loom was also routed below the valve when I stripped the vehicle ( many years ago!), as the fixing strap holes are still evident? ( I suppose this could be re-routed to the side ?)
Any thoughts on what the correct safe clearance should be - and how to resolve it?
Should it be at least 1/2", more, or less ?
Or am I worrying too much and this is normal?
Is it possible to get the engine mounts mixed up side to side, if so, do they produce different heights in engine position, etc.?
Then there's the rocker box filler cap / bonnet clearance issue, if the engine is raised! ( I haven't really checked this clearance yet as the rocker box is not installed - suppose I've got that to come!)
Triple whammy problem methinks ?
Your assistance and guidance would be appreciated, as ever.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
My s3 has this adaptor, which takes the heater valve right away from the bodywork. Standard plumbing fitting, cheap as.......
- robertverhey
promotor wrote:Couldn't the heater valve and thermistor swap places? Is a longer cable available?
Yes, If you are not insistent on originality, the simplest option is to swap over the heater valve with the temperature gauge bulb. Mine have been swapped over since about 1983.
You may have a problem doing this if the heater control knob wire is not long enough, but in my case they just fit.
But as implied by robertverhey above, the threads are standard UK plumbing threads and a trip to B&Q gives you many possible options for moving the valve a bit. I've even contemplated replacing the Lotus valve with a bog-standard washing-machine water supply tap, which is much more compact and has actuating shaft to which a suitable lever can be added with relative ease.
To answer a couple of your questions, "almost nil" is definitely wrong. It'll turn into nil in no time. There are lots of threads in here about correct engine mounts for Weber and Stromberg engines. You can easily get them wrong and they will screw with the engine height.
My regular check for pending engine mount expiry is to be able to run my fingers under the heater valve and the carburetor airbox reasonably easily - a slight squeeze for both gaps.
I seem to be in the habit of doing it to every Elan I see, which is rather rude.
Nick
Nick
elanner - Fourth Gear
Phil,
Just checked my S4. I have approx' 20mm clearance below the heater valve. I also measured the difference between installing the L/H engine mount the right way up and upside down. The difference is approx' 20mm. Worth a look?
Also, my main wiring loom is outboard of the heater valve, but only just.
Colin.
Colin.
l10tus wrote:Next Issue:
Phil.
'68 S4 DHC
- fatboyoz
Great replies, thanks Gents.
I think I need to check my engine mount types - can I have more detail please?
New chassis, new engine mounts, body off refurb - maybe the body isn't seated correctly ?
Just several factors to get right all at once!
I'll update the thread as more is found out and (hopefully ! ) - issues are rectified.
How much filler cap / bonnet clearance should there be then ?
Help is much appreciated,
Many thanks,
Phil.
Many thanks,
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
Phil,
For pictures of various engine mounts look here: http://www.sjsportscars.co.uk/index.php?mod=10
The closed section of the mount goes at the top. This allows the closed section of the mount to rest metal on metal when/if the rubber fails.
Colin.
Colin.
l10tus wrote:Great replies, thanks Gents.
Many thanks,
Phil.
'68 S4 DHC
- fatboyoz
l10tus wrote:Or am I worrying too much and this is normal?
Yes!
Provided you have the engine mounts the correct way round.
The engine is tilted down on the exhaust side. The torque reaction from the engine is in the opposite sense so the gap normally increases on the exhaust side and the carbs hit on the other side - Your carbs are less likely to hit the footwell.
Get her on the road and worry about it when you have a problem - You must be nearly there by now!
I would worry more about the nylon vac hoses being too close to the exhaust and melting. Take some slack out and tie them to the wheel arch with a P Clip.
- AHM
Thanks AHM, I had thought they were a little close to the exhaust!
It's just when I look at pictures of other engine bay installations, everything seems to be neat and tidy, but try as I may, mine always looks as if it could be better !
Yes, nearly there now, hopefully should be all basically sorted and up and running in a month.
I feel better about the clearance of the Heater Valve, now I know the engine torque's the other way, although, " every action has an equal and opposite re-action " doesn't it?
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
It occurs to me that there isn't an engine mount that would put the heater valve too low. The regular ones (Weber exhaust-side & Stromberg) would make the height correct, while a Weber inlet-side mount would make it too high. Is that right?
So if the valve is too low the mount must be knackered or upside down?
My heater valve was resting on top of the footwell a couple of years ago and when I got the mount out it was, indeed, totally knackered. In two pieces. I had changed the inlet side mount a week or two before because the airbox was thumping the footwell. At the time the exhaust side mount seemed fine. But the strong new inlet side mount apparently overwhelmed the exhaust one, which promptly failed in disgust. So in future I'll change them in pairs.
Nick
Nick
Well I checked the exhaust side mount and it's the correct way up!
Both mounts were brand new 5 years ago when I started the rebuild!
The engine has not run since, so the mounts can't be knacker can they?
I have now noticed the nearest stainless steel exhaust downpipe is awfully close to the fibreglass corner of the footwell body also !
So where do I go from here ?
The heater valve will snap if it's left in its current position, that's Bound to happen at the most inconvenient moment - you can bet your bottom dollar!
Things are not looking best good here!
RECAP:-
Footwell fibreglass is going to burn.
Heater valve is going to snap off - with engine vibration.
Filler cap will foul the underside of the bonnet .
Phnumatic tubes will melt.
Wiring loom gets rubbed into pieces !
Oh Jesu! I've constructed a failure!
How much of this is reality???
RECAP:-
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
Phil,
If the body is sitting correctly on the chassis and the engine mounts are correctly fitted and in good nick, I don't see how you could possibly have a clearance problem. Could you post some pictures of your mounts so that all and sundry can pass an opinion?
I have used reflective type, self adhesive heatshield material to protect the fiberglass in the vicinity of the extractors.
Also, the heater valve does not appear to be the correct part. The lever should be at the bottom. The item fitted also appears to be in the closed position. To open the valve it looks like the lever would have to be moved toward the front of the car. To do this the knob inside would have to pushed toward the dash. IN for OPEN, OUT for CLOSED. This would be working in the wrong sense.
Colin.
Colin.
'68 S4 DHC
- fatboyoz
