S4 and Sprint airflow vents
PostPost by: SADLOTUS » Thu Oct 27, 2011 7:33 pm
Hi all
Don't need them at the moment but after explaining to a neighbour about the Elan being a car of many sources he asked where the the airvents came from.... er... Rover 3 litre? I suggested - don't know why just a guess from a distant misty past. having surfed Rover dahboards for half an hour I don't think so.
Someone enlighten me please :roll:
ta
Paul
SADLOTUS
PostPost by: types26/36 » Thu Oct 27, 2011 8:32 pm
SADLOTUS wrote:Don't need them at the moment Paul
I'd also like to know where they came from as I DO need two......anyone got a couple for sale? :(
types26/36
PostPost by: trw99 » Thu Oct 27, 2011 9:22 pm
They came from the +2 heater air inlet grill. Find a +2 being broken and ... Bob's your air grill.
PostPost by: types26/36 » Thu Oct 27, 2011 10:14 pm
Hi Tim,
Maybe I've got my wires crossed :oops: but I'm looking for the small round air ducts at each end of dash (they fit into the plastic piller trims and have a flip type disc to open/close) .....are we on the same page :?
types26/36
PostPost by: trw99 » Fri Oct 28, 2011 5:16 am
Duh!
I thought you meant the FHC side air vents in the roof behind the windows! Sorry. Yep, the dash vents are from a Rover 3 litre.
PostPost by: garyeanderson » Fri Oct 28, 2011 9:22 am
Sadlotus
Your camera skills are simply amazing!
top of crashpad?, Dimister outlet?, pillar outlet?
Gary
I think top of crashpad vents are airflow Cortina mk1, same with the others except they are Cortina mk2 (eyeball and pillar)
I've been wrong before and don't much care any more!
Gary
garyeanderson
PostPost by: Elanintheforest » Fri Oct 28, 2011 9:34 am
And here they are lurking in the corners of a P5 dashboard...grotty picture, but you can just about make them out.
Someone only told me about these this week...quite a coincidence.
The trouble is....how many P5s do you think are still left? A darned sight less than the number of Elans I'm sure!
std_1969_rover_p5_v8_3,5_l-2.jpg and
PostPost by: ardee_selby » Fri Oct 28, 2011 10:56 am
Elanintheforest wrote:And here they are lurking in the corners of a P5 dashboard...grotty picture, but you can just about make them out.
And, out of shot, a pair? of these...
Elanintheforest wrote: The trouble is....how many P5s do you think are still left? A darned sight less than the number of Elans I'm sure! Mark
Not many and maybe, whatever the number, more LHD than RHD.
Cheers - Richard
ardee_selby
PostPost by: oldelanman » Fri Oct 28, 2011 11:40 am
types26/36 wrote: I'm looking for the small round air ducts at each end of dash (they fit into the plastic piller trims and have a flip type disc to open/close)
Might be worth giving these people a ring. Can't see them listed but you never know......
https://www.jrwadhams.co.uk/index.asp
S4 DHC
PostPost by: elanfan1 » Sun Nov 06, 2011 7:57 pm
For those in need:
http://www.ebay.co.uk/itm/120806881141? ... 1586.l2649
Oh and be careful of assuming all the Rover ones are correct - some have a different shaped cowl fitted to the front and the tube is noticeably shorter - good if you just need a donor inner disc but not for much else (ask me how I know!!).
PostPost by: elansprint71 » Sun Nov 06, 2011 8:36 pm
Confession time.... actually this response does not relate to the little vents in the Elan but concerns the large eye-ball vents in the Cortina. :oops: :oops:
Many years ago I was asked to design a "fresh-air ventilator" for the humanoid life-forms who sat at Royal Mail's letter-coding desks for eight hours a day (or, more probably, night). These unfortunate individuals sat in an uncomfortable chair and typed the phosphor code-marks onto letters, which appeared right to left on a moving belt on an easel. The faster one typed the quicker the next letter appeared. It was not unknown for newbies to fall off their perch after 40 minutes, even the old-hands could be observed staggering to the on-site bar after two hours.
Anyway... the folks in the Ivory Towers asked me to see if I could make the task a little less onerous. First thing I did was provide a (mono) headphone socket, with choice of four radio stations (hey, this was 1970's!) then I drew up a fresh (well, ambient minus the dust) air system; what form of outlet control to use...? Best thing I'd ever seen was the Cortina eye-ball vent, only problem was the Cortina was long out of production. Many phone-calls to Ford later and the bloke who's job it was to unload surplus stock told me where I could find the entire recently disposed-of stock. I bought the job-lot, just under 400 units.
So my profound apologies to Cortina restorers, I'm ashamed to say that when the coding-desks were scrapped, some years later, the vents went with them. :oops: :oops: :oops:
Last edited by elansprint71 on Mon Nov 07, 2011 12:04 pm, edited 2 times in total.
PostPost by: SADLOTUS » Sun Nov 06, 2011 8:44 pm
tut tut shame on you Pete!
ooh look another eyeball vent: ebay no: 160677587145
...you wait all year then two come along together!
P
SADLOTUS
PostPost by: elanfan1 » Mon Nov 07, 2011 12:16 am
Isn't that bloody typical!
PostPost by: Elanintheforest » Mon Nov 07, 2011 8:52 am
With over a million Mk 2 Cortinas made, so 2 million eyballs, and something less than a couple of thousand cars left, I don't think that there will be a shortage of Cortina eyeballs anytime soon....they were Elan Plus 2 items as well, so add another few thousand on!!!
I think that the teeny weeny Elan / Rover ones may be further up the endangered species list.
PostPost by: types26/36 » Mon Nov 07, 2011 10:32 am
I believe the large one is also the type fitted to the Europa.
Picture 013 (1000 x 750).jpg and
types26/36
Next
Users browsing this forum: No registered users and 49 guests
