Heater water valve
Yet another question from me... as you can guess, I'm at the sort-out-the-details stage as the basics are now close to right (rear Konis and 3.54 diff going in this weekend).
I've fitted a new heater valve. How do you get the thing to turn off without doing it manually under the bonnet? The last bit of movement into the detent requires such force that the outer cable stretches before the valve lever moves that final few degrees. New inner and outer cables too. Is there a way of modifying the valve to make the movement easier? I've tried smoothing off the angles in the slot in which the lever moves, and twisting both sides of the lever to reduce the angle of attack, but though better it's still too stiff at the cold end of the travel.
Maybe it's a 'standard' fault. Various contemporary road tests mention the impossibility of turning the heater right off.
- johnsimister
Mine turns off completely. It's just a matter of freeing up the mechanism with a little grease and setting up the cable so it wants to go past the point where it turns off.
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
Frank Howard wrote:Mine turns off completely. It's just a matter of freeing up the mechanism with a little grease and setting up the cable so it wants to go past the point where it turns off.
Well, yes, but that's exactly what I've tried. Maybe with a few years' use it will finally concede defeat and work as it should.
- johnsimister
Mine never sticks.... (purists read no further)
I replaced mine with a simple, (Ford truck) inline heater valve more than 25 years ago. It hooks right up to the cable, and has operated perfectly. The only adaptation required was a 90 degree elbow fitted to the head, and a little trim of the heater hose.
The original now resides about an arm's throw away.
- elancoupe
My car is indeed not a Plus Two. It has the standard valve. Changing it for a better inline one does indeed sound the way to go, and I'll just live with the non-standard appearance. It will go well with the Spyder chassis, Pacet fan and Cambridge Motorsport starter.
Thanks to all for suggestions/commiserations.
- johnsimister
I bought one of these a while ago intending to fit later on with my restoration
http://cgi.ebay.com/ebaymotors/Lotus-TV ... 240%3A1318
whilst not yet fitted the valve certainly moves more freely than the original
Nigel Robertson
robcall - Third Gear
They have one for a +2 too:
http://cgi.ebay.com/ebaymotors/Lotus-TR ... 240%3A1318
Where do these things mount?
Sean.
Sean.
- alaric
I believe the seller has the wrong pictures loaded. I cannot vouch for the +2 variant, but the one that says it is not suitable for the Elan is a push to close - and therefore, is the correct Elan part.
For people thinking of buying from this seller must get confirmation of the pull or push closure before parting with money.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
well-i had to go and pull the valve out from my spares boxes for a look-see.
You guys are quite correct-the "elan" valve is a pull to close valve and as such unsuitable.
I will email the seller about this
well spotted guys-I could well have fitted this later on without thinking it through
Nigel Robertson
I'm thinking of replacing the stock HCV with an inline. Does anyone have a specific reference for an elbow fitting? It's got to be 3/8" BSPT, correct? I can't seem to find an elbow fitting with BSPT on one side, and 1/2" (?) hose on the other.
Thanks in advance,
- Mark
Thanks in advance,
- Mark
- dogmotor
