Plus 2 heater hose diameter
PostPost by: vernon.taylor » Sat Mar 23, 2013 9:43 am
Salut
Checked the archives but couldn't find an answer - anyone know the heater hose diameter for a Plus 2, please?
Looks like the diameter is larger at the heater outlet and then a standard 1/2 inch at the thermostat and water pump?
Merci
Vernon
vernon.taylor
PostPost by: TeeJay » Sat Mar 23, 2013 11:30 am
Hi Vernon.
Just popped into my garage.
Heater Outlet at 15.8 mm.
Water Pump At 13 mm.
Will upload some photos shortly.
Trevor
1968 Elan +2 50/0173
PostPost by: TeeJay » Sat Mar 23, 2013 11:42 am
Just resized the photos, hope they are ok.
Note my +2 is a 1968.
Heater Outlet.jpg and
Heater Outlet at 15.8mm
Water Pump Outlet.jpg and
Water Pump Outlet at 13mm
Trevor
PostPost by: vernon.taylor » Sat Mar 23, 2013 4:05 pm
Fantastic, thanks Trevor.
Vernon
vernon.taylor
PostPost by: CBUEB1771 » Tue Mar 26, 2013 1:55 pm
I always thought this was an annoyance on the +2, not being able to use a length of standard 5/8" bore heater hose. I was about to make up a hose barb with 5/8" OD for the water pump housing until I found that Steve at Lotus Marques in Australia has them:
http://www.lotusmarques.com/parts/catal ... pump-parts
I had a long list of parts I needed from Steve so I added a couple of these hose barbs to my order. Interestingly the combination of the 5/8" barb and the correct BSPP thread is very unusual, I could not find one at any hydraulics suppliers. Easy enough to make on a lathe but I like to save time.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: vernon.taylor » Thu Mar 28, 2013 7:51 am
Good find, Russ. Cliveboy is looking into making up silicone heater hoses for the +2 so I'll probably go his route.
Vernon
vernon.taylor
