Working out my diff ratio
I've got one of my drive shafts off at the mo on my 130S/5 while I was under the car I decided to check out my dif ratio. One out put shaft was locked so it didn't moved. I turned the input shaft and measured the number if turns it took to turn the output shaft one revolution.
I measured around 1.875 rotations of the input for one turn off the output. As one output was locked so it didn't move do I double the number. That would make the diff a 3.7:1.
Current Cars: '72 Elan +2S130/5, '72 Triumph Stag 3.9L, '72 Spitifire Mk IV. Past Cars: '72 Triumph TR6 (supercharged), '70 MG Midget (K-Series + Type 9), '76 Triumph 2500TC, '72 Lotus Elan +2S130/4, '76 Triumph Spitfire 1500.
- shynsy
That's the most prevalent, and "standard" diff ratio, although obviously there are lots of others, as Colin used the differentials from the Ford "English" axle.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
JonB wrote:You can also work this out from the plastic speedometer drive gear in the gearbox - different colours for different diff ratios. Always assuming your gearbox and diff are original, of course.
OK what colour for the 5 speed 3.7 diff.
- shynsy
Sorry, I don’t know. I was looking it up but not found it yet. Actually was hoping someone else would enlighten you…
Edit: quick search turned up this : viewtopic.php?t=36413&f=37&start=0#p249714
JonB - Coveted Fifth Gear
