Modified Bell Housing
PostPost by: AlanJH » Tue Oct 01, 2024 9:40 pm
I have to ask if anyone is familiar with a bell housing modification like this?
2 large holes and a small threaded square headed bolt, not sure what else to call it. The bolt doesn't tighten, but I can remove it. I'm wondering what the modifications are for and what the potential issues could be having the clutch exposed this way. Also, I doubt it effects the structural ability of the bell housing, but it definitely doesn't improve it. I've looked at many photos to find a similar modification, but I haven't seen it.
All comments on this welcomed.
1614178543bc4f875f0d6c1eddIV5A5441-scaled.jpg and
Alan Hill
1967 Elan S3 SS
Delaware
AlanJH
First Gear
First Gear
PostPost by: ericbushby » Tue Oct 01, 2024 9:56 pm
First Suggestion,
It has been cut to prise the clutch off the flywheel when it sticks from being unused too long.
Put a grommet in it.
Eric in Burnley
1967 S3SE DHC
PostPost by: 2cams70 » Wed Oct 02, 2024 3:41 am
Why do some people insist on butchering old cars?
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: alan.barker » Wed Oct 02, 2024 7:21 am
Hi Alanjh,
Is there a "sandwich plate" between the Engine and Gearbox.
PostPost by: AlanJH » Wed Oct 02, 2024 11:36 am
Thanks for the answers, seems extreme but plausible to free the clutch, I’ll try grommets, but with the curve of the bell housing it might be difficult to keep them in place, if I get the ambition I might try and fabricate a cover.
I don’t think there is a sandwich plate, but through the forward hole I see what I thought was the flywheel, I’m not familiar enough with the parts of the car I haven’t taken apart yet and hope it is the flywheel and not a spacer between the clutch and flywheel. Please tell me the flywheel is normal and not another butchered modification.
Alan Hill
1967 Elan S3 SS
Delaware
AlanJH
First Gear
First Gear
PostPost by: ChrisD » Wed Oct 02, 2024 1:31 pm
Propably someone had a gear box oil leak and found out that the lower bolt that puts the bellhousing and gearbox together needs to be put in with seal paste...
I know this problem well...
Christian
ChrisD
First Gear
First Gear
PostPost by: alan.barker » Wed Oct 02, 2024 1:34 pm
If you remove the Starter Motor you will see
If a sandwich plate has been fitted.
It is needed to position the Starter correctly.
There should also be a closing plate.
PostPost by: pharriso » Wed Oct 02, 2024 2:31 pm
alan.barker wrote:If you remove the Starter Motor you will see
You can see the closing plate in the first picture...
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: alan.barker » Wed Oct 02, 2024 7:30 pm
Yes just zoomed in your right Phil
Users browsing this forum: Neil Spooner and 16 guests
