Diff oil
My understanding is that it should be GL5. I received this advice from a friend who worked in the oil industry and used to design oils.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
Thanks all for the input
Having the chance to get the car on a ramp today I changed the gearbox oil but the differential was another matter
On inspection I could not see a drain plug Very strange so I could not change it
In the end I just topped it up with ep 90
Is this something which lotus did on certain diffs.My sprint is a 73 car so bit baffled
G
G
- MACCA.GLM
Drain plug
Just make sure you can get to the fill plug on the back before removing the drain plug !
'72 Sprint
'72 Sprint
- richardcox_lotus
Users browsing this forum: Neil Spooner and 15 guests
