Differential torque rod
PostPost by: gjz30075 » Thu Apr 04, 2024 8:46 pm
So, looking at the torque rods on my 67 S3, I see a nylock nut on the end where normall
a conical nut would go. When I pulled the torque rods, I see the end of both rods are
flat, ie, no concave for the conical nut. Probably aftermarket rods?
The question is then, how important is having the concave on a torque rod with the
conical nut? My thinking is, apparently not so.
What say the collective minds?
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: smo17003 » Thu Apr 04, 2024 9:38 pm
Hi Greg,
Flat on my 67 S3 and concave on my 68 S4 so I'm sure that is was a later modification to improve location of the rod.
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: rgh0 » Thu Apr 04, 2024 11:23 pm
I would machine a cone on the torque rod and a cone on a nyloc nut as the welded in stud in the chassis will wear if just a plain nut is used
PostPost by: gjz30075 » Fri Apr 05, 2024 12:00 am
My Sprint has concave rods with cone nuts so this could have been a running change and to Rohan's point,
an engineering change deemed important.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
