torque rods
simple but annoying....
when installing the torque rods i cannot get the washer cups to sit under pressure on front and rear of sow ear, the rear is loose on right side and front on left side of "ears" it like both seem to be floating in the recess.
I have changed sides and it it does is swap over the front rear scenario above
Any suggestions,
Brand new rubber bushings being used, rods have welded front cup.
Any suggestions,
- street
One suggestion - I really think you need to get yourself a digital camera or phone with camera so you can post pictures to help explain what you are trying to describe. Remember too it’s difficult to turn a sow’s ear into a silk purse
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Sound like the diff is not fitted " square" to the chassis/propshaft ?
Yup - it should be simple, assuming you have the correct bushes & washers. Note the assembly sequence in the workshop manual:
The torque rod rubbers are assembled in the following sequence from the front:-
Rubber bush (next to fixed washer), cup washer with large hole, differential unit lug, cup washer with large hole, rubber bush, cup washer with small hole, and finally the nut which should be torque loaded to the figure given in 'Technical Doto'.
It's hard to get the washers wrong, because the small hole washer will only fit at end of the rod, next to the nut, while the large hole washers will slide along the rod, over the step at the end. Are you sure you have the correct bushes? If yours are too thin you'll never be able to get them tight.
Nick
Nick
elanner - Fourth Gear
Can I, slightly, hijack this discussion ?
I just recently found that my torque rods had no washers— just the rubber bushings. I found a couple anti-roll bar washers that fit the front of the ear and used two tapered higher duration suspension bushings at the rear.
My question: What is the purpose of the tapered hole and tapered nut at the end of the torque rod ? The previous owner had severely tightened down the tapered nuts and lock nuts.
Second question: Should the tapered nuts be left a little loose(with locking nut tight) to allow some rotational movement or should they be tightened down ?
- Rickrey
The tapered washer into the tapered recess of the torque rod provides for a higher strength and more stable (in shear) bolted joint than a plain bolt and washer through the torque rod would. That nut needs to be very tight here! The fore/aft forces generated by the diff housing under loading and unloading are quite large, and the torque rod bushings need to be in good condition with everything tight or you will risk stress cracks at the torque rod forward mounting points.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
billwill wrote:I have a recollection that the washers for the bushes are slightly cupped, not flat, but I don'r remember for sure and haven't found a diagram.
The washers that I have are as Bill describes; flat on one side, domed on the other. The parts list shows a nut and washer on both sides. I've never found a source for the washers. In a pervious thread it was noted that Kelvedon Lotus sells a "Torque Rod Nut" shaped to fit. That might be good if used with a lock nut????
https://kelvedonlotus.co.uk/product/dif ... e-rod-nut/
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Exactly. Started at one end then switched to the other. Both ends covered at this point I think.
What you pictured is what I have on my '70 +2 as well.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
