Diff issues coming?
PostPost by: loueelotus » Sat Jan 21, 2023 3:45 pm
Hi ,
I noticed a noise from the driveline / Diff at the end of the season when pushing my Lotus Elan S2 in 2nd gear. So I lifted the car as every winter, removed the tires and did my inspections. I thought it may be the u joints but after checking them they seem good as were the donuts with no leaks around the diff. I tried to hear where the click came from to no avail.. So I put the left wheel on and rotated the tire 10-15% back and forth quickly . All seemed good so I decided to do the circumference of the wheel about 15% each time. I found that there was a small area that when I moved it quickly the click came. This was done in neutral. Now I will do the same on the right side which seemed better several weeks ago when checking the u joints.. It just seems to be one spot on the left side.
Diff issues coming?
Thanks for your input,
Lou
Louis Lottner
Elan S2 1965 #26-4840
Colin Chapman’s immortal words ‘Simplify, then add lightness’
loueelotus
PostPost by: h20hamelan » Sat Jan 21, 2023 4:14 pm
How is the diff oil
Drain, look at in thin pan. See any metal?
Love your Mother
Earth
