Diff top mounting bushes
Hi, is it possible to fit new bushes to the diff top mounts whilst the diff is still in situ and with the body on the chassis?
Andy
Andy
Sept 1970 Plus 2S, KOO38J Glacier Blue, 50/2432 (was Carnival Red)
- Andy Hamblin
I wouldn't think so, they drop in from the top and are bolted down from the top into welded-on nuts in the rear cross member
It's just about possible to get an open spanner onto the diff mounting bolt nuts when taking the diff out.
You could possibly remove the fuel tank and open up the openings in the fibreglass.
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Andy Hamblin wrote:Hi, is it possible to fit new bushes to the diff top mounts whilst the diff is still in situ and with the body on the chassis?
Andy
Have a look in your boot, under the carpet.
You need access to the central diff supporting bolt and the 2 bolts that hold in the bush.
If you can't see them , you can always cut away the floor in an ellipse big enough to do the job, as I have just done.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Yes it's possible but a bit fiddly
Biggest job it removing trim to gain access
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Yes, very easy
- alan.barker
Andy
On a +2 access to the diff mounts is via the back seat area and not the boot as someone suggested. Remove rear seat and trim and you will be able to see the mounts. You may have to slacken the tank straps off slightly but all perfectly doable.
Note:- Diffential ears to the mount bolts go upwards and not as some twit had done in my case and put them downwards!
If you find likewise this has been done you will have to take the tank out!
Alan.
Currently:-
1971 +2 S130/ 5speed Type 9.
Currently:-
- alanr
To replace the diff mounts on a +2 I think you need to lift the tank a good few inches to be able to lift the diff mounts out. Which likely means draining and disconnecting the fuel outlet on the tank as well. Maybe there just enough room by lifting it as high as it can with out disconnecting the fuel line but I think it would be pretty tight.
- mbell
I have replaced them twice each time I did not have to move the tank, there is a resess on the tank at the side nearest the passenger seats.
Look see it is doable
+2s130 1971
+2s130 1971
Hawksfield wrote:Hi
I have a replacement alloy tank that completely covers the mounting apertures, it'll have to come out.
- Andy Hamblin
There something to be said for originality.
You will have to lift it high and that requires the pipework disconnection
Just more work but you need good diff support bushes.
+2s130 1971
+2s130 1971
I had to enlarge the holes just to get tools on the fasteners; the two toward the front were each overlapped by the fibreglass.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Looked at mine and I reckon it’s doable with the tank in situ but easier with it out and I have an ally tank fitted. While you are doing it, it would be worth fitting the diff brace bar although on a Plus 2 this can be done another time but would save a lot of repeat work if you do it while changing the top mounts.
- Bigbaldybloke
Bigbaldybloke wrote:Looked at mine and I reckon it’s doable with the tank in situ but easier with it out and I have an ally tank fitted. While you are doing it, it would be worth fitting the diff brace bar although on a Plus 2 this can be done another time but would save a lot of repeat work if you do it while changing the top mounts.
Thanks for that, I have got the tank out now, so plenty of room.
Mine doesn’t have a diff brace, were they factory additions to later cars or just after market mods? How do they fit and any idea where can I get one? cheers
- Andy Hamblin
Factory fitment on later cars. They mount between the diff ears and rubber mounting bushes, in place of one of the washers. Should be available from pretty much any of the normal parts suppliers.
- mbell
