3.55 rear end
PostPost by: Lotus 50 » Mon Mar 08, 2021 3:23 pm
The standard gears of course make for a lot of revs on the highway. Has anyone tried 3.55 gears? RD has a used differential with 3.55 gears. Worth the change? It would only be a couple of hundred rpm.
Lotus 50
PostPost by: jono » Mon Mar 08, 2021 5:52 pm
I did it on my Plus 2 but reverted back to a 3.77
It made a small but noticable difference on the motorway however that did not offset the slightly blunted acceleration and increased effort getting off the line, especially on a hill.
I concluded that Lotus got it pretty much bang on with the 3.77 which to me suits the car nicely.
PostPost by: Billmack » Mon Mar 08, 2021 7:12 pm
If you have 3.9 change to 3.55 rpm drops 9 percent more or less. If you have 3.77 and go to 3.55 rpm drop is about 6 percent.
Billmack
PostPost by: Baggy2 » Mon Mar 08, 2021 9:47 pm
I guess it depends on how you want to use your car. I've just installed both a 3.55 diff and a 5 speed Lotus gearbox in my +2 at the same time - I still have 13" wheels. And I'm very pleased with the result. Whilst on minor roads I find I don't use 5th gear as often as I had expected - the car is quite happy in the higher 4th gear. Acceleration is still fine for normal road driving and I haven't noticed any problem pulling away.
This is in a +2 used for general day to day motoring - the picture might be different in a two seat Elan possibly used for occasional competitive purposes.
I wouldn't change back.
Just my two penneth
Baggy2
PostPost by: TBG » Mon Mar 08, 2021 10:19 pm
If you go for a 3:1 and you have the power all is pure joy - but I have banged on about this before!!
Deller visit 2013 (4).JPG and
TBG
PostPost by: rgh0 » Tue Mar 09, 2021 9:47 am
3.55 with the Lotus 5 speed works well with good acceleration off the line with the lower first and then great cruising in 5th gear on open roads ... works for me in my Plus2S 130/5 with lower profile 175/60 x 13 tyres and Australian speed limits
PostPost by: TBG » Tue Mar 09, 2021 11:17 am
Speed limits? What's that then Rohan!!
Speeding.jpg and
TBG
PostPost by: elans3 » Tue Mar 09, 2021 12:51 pm
My S3 S/E has the 3.55 diff with the close ratio (2.5:1) 1st gear, and I find it perfect, no problem pulling away, and much better on the motorway. However, I can see that it may present a problem for some, with the heavier +2, particularly with a standard engine.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
elans3
PostPost by: prezoom » Tue Mar 09, 2021 4:42 pm
I have a 3.55 coupled with a close ratio gearbox in my Plus2. I did notice a slight loss of acceleration from the 3.77, but not enough to make much of a difference. Disclaimer, the car is also equipped with a 2L Zetec and an aluminum flywheel. Have not yet found a hill steep enough to cause a problem pulling away from a stop. Additionally, my Sabra is equipped with a 3.55 and 165/15 tires, a ZF gearbox , with a 2.5 first gear, and has no problems with hill starts even having much less horsepower and torque, but with a flywheel weight of that of a diesel truck. Get the flywheel spinning and it will even crawl up my steep, but short, driveway at an idle. Inertia can be your friend at times.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: mbell » Tue Mar 09, 2021 6:56 pm
I too have Lotus 5 speed, 3.55 diff but with 175/70r13 tyres. Generally find it good for the open road, I do find 2nd is a little tall slower speed driving in car parks etc but not a major issue.
PostPost by: Lotus 50 » Tue Mar 09, 2021 8:50 pm
I put this post in the Plus 2 discussion, rather than technical, as the Plus 2 is heavier and might need different gearing then the standard Elan. Thanks for the information. I will stay with the current gearing.
Lotus 50
