S2 26R rear hub bearing replacement
PostPost by: jabingb » Wed Oct 07, 2020 7:27 pm
Before I do something untoward, does anyone have experience with this procedure, tips/hints appreciated! The left side definitely needs attention so I'll do both sides before the body goes back on the chassis for painting.
Just a thought, if anyone here in the States has a rear hub puller I'd appreciate borrowing it as I suspect I'll only use it one time, I see Kelvedon does sell one.
IMG_7347.JPG and
Jerry:
'61 S2 Elite | '69 S4 Elan FHC | '00 S1 Elise Sport 190
jabingb
PostPost by: Elan45 » Sat Oct 10, 2020 2:34 am
I'd be happy to loan you the pair i made over 35 years ago, but they are for the standard rear hubs, which I think are 10 TPI thread , while the 26R hubs are 8 tpi. I haven't taken my 26R apart yet, so I'm not sure how the tool will have to work, but I also don't have access to the lathe I used back then, so maybe I'll have to buy a pair from Kelvedon.
I do know the 26R ser 2 rear hubs do not have the tapered stub axle/ hub interface, so I'm wondering if a hub puller is actually required. I have a single spare hub/stub axle and it is so different, more like a racing part.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: StressCraxx » Sat Oct 10, 2020 2:47 am
Jerry,
I have the one that RDent sells. Threaded to work both sides. PM me if you are interested.
StressCraxx
PostPost by: vstibbard » Sat Oct 10, 2020 8:52 am
no puller is required as you release it from the outer UJ joint.
V
