Wheel Came Off
• Page 1 of 4 • 1, 2, 3, 4
On holiday in France heading over to ile d'Oleron on the west coast. We had been touring down the N10 but decided to make up some time and got on the A10. After a peage(toll) stop and accelerating hard I felt a bit of rear wheel steering and then the car slammed down on the drivers side rear, the wheel came off and overtook us. Fortunately we managed to coast/grind to a halt on the safety strip without too much drama (we thought). We had been doing 130 KMH. The wheel ended up on the safety strip about 200 meters ahead of us. The rear suspension dragging along the tarmac sent a shower of sparks on to the tinder dry grass and set it on fire. Once stopped I had to run back with the fire extinguisher carried in the car to put out the roadside fire.
Then back to recover the wheel and assess the damage. The hub shaft has sheared at the hub end. I am assuming this is just metal fatigue brought on by a combination of age and some level of aggressive driving on the track days we do. The car has a 145 BHP 1700 twin cam, and I use Michelin XAS tyres which are very sticky when hot.
I have replaced the inner output shafts after one broke on a track day, driving to the pit lane. I have Sue Miller CV joints, but have never thought about the hub shafts. Does anyone have any guidance/advice/experiences to share about replacements shafts. I will do both of course and presume there are some soild billet types available. No doubt there is an element of price/performance in the choice but given what I use the car for they will need to be strong.
A few photos to share.
Martin
Martin
1967 Elan convertible S4 body and Spyder chassis
Ducati Monster S4
Ducati 1098s
Ducati Monster S4
Ducati 1098s
- MartinH
TTR sells shafts that don't break in my experience. I did an original shaft in my Elan about 25 years ago on the race track and changed them both then, no problems since. At least you don't have the hassle of removing the hub to replace the shaft. You may also need a new hub if the taper is damaged.
They usually break at the big end of the taper near the bearing I have not seen one fail at the nut end like yours.
My sympathies. I had pretty much the same thing happen not long after I bought the car. Mine went on the A1 near Peterborough with a friend of mine - a traffic cop! - in the passengers seat. The scars on the bottom of the strut are still there.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Blimey, not seen that before.
At least you came to a controlled stop.
I hope you get home safely.
Looks like you'll have plenty to do in your 2 weeks quarantine
The TTR 26R S2 set up I have looks unbreakable................( but see the threads on it's quirks, wont go with your Sue Millar shafts). They may do billet outer shafts for the standard style hub setup, which would be the easiest way to go. ( ? need new hub and carrier???)
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
When I was rebuilding my struts I seriously considered seeing if it was possible to fix a ring of nylon (or similar) to the bottom of the strut to act as a sacrificial "skid" if the shaft broke / wheel came off etc.
Easier slide and less damage.
- vincereynard
69S4 wrote:A cut down motorcycle racer knee slider would probably be suitable material.
Exactly! Even give some tasty sparks. How to securely attach however?
- vincereynard
Do you intend to do this on a regular basis?
MartinH wrote: Does anyone have any guidance/advice/experiences to share about replacements shafts. I will do both of course and presume there are some soild billet types available. No doubt there is an element of price/performance in the choice but given what I use the car for they will need to be strong.
Martin
I have TTR F1 billet shafts with no keyway. Seem to be the best (strongest) option available. Paired with CV's (from Dave Bean). No mating problems.
I have 26R hubs, so you need to verify that the TTR shafts work with standard hubs.
I see Matty also has shafts (Quaife).
None are cheap.
Just be sure to lap the hubs/shafts carefully to ensure a proper tight fit.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Users browsing this forum: No registered users and 46 guests
