Installing Rotoflex Couplings with Body Off
I'm finishing up the rebuild of the rear suspension and rear drive train. Everything is renewed and reinstalled but the rotoflex couplings. The body is currently off the chassis, so I don't think I have anywhere near enough weight to depress the rear springs sufficiently by just jacking up the rear hub, to install the couplings. Anybody ever do this successfully?
Tony
1967 Elan S3 SE
Northeast US
1967 Elan S3 SE
Northeast US
- Tmac897
Another way is to string multiple hose clamps through the springs to compress them so the wishbones are level.
StressCraxx wrote:Another way is to string multiple hose clamps through the springs to compress them so the wishbones are level.
Have yo tried this in the past? Concerned that hose clamps might not support that much force.
Tony
1967 Elan S3 SE
Northeast US
1967 Elan S3 SE
Northeast US
- Tmac897
Why not simple spring compressors?
Unless you know otherwise I'd have my doubts about
hose clamps. (Plus concrete blocks?)
Good tie down straps would have sufficient strength. Breaking strain well over a ton. I use then to "jack" the drive shaft level to give the best angle of attachment.
- vincereynard
[quote="vincereynard"]Why not simple spring compressors?
/quote]
The “hooks” on the spring compressor I rented from Autozone we’re pretty bulky, and will only fit on about the middle third of the spring. To get the springs and shocks to fit up in the lotocones I had to compress, tie down with zip ties, take the spring compressors off, then fit them on and snip the zip ties. Might be worth a try though.
/quote]
Tony
1967 Elan S3 SE
Northeast US
1967 Elan S3 SE
Northeast US
- Tmac897
I would not fit the rotoflex couplings until the body if on unless your going to leave the rear suspension compressed. The high couple deflection angle for the time it takes for the rest of the car to be completed risks causing cracking and shortening the rotoflexes life
Tmac897 wrote:StressCraxx wrote:Another way is to string multiple hose clamps through the springs to compress them so the wishbones are level.
Yes. I used 4 per spring. Stock springs are only 78#/inch IIRC. I also used them to change dampers with the body on the car.
rgh0 wrote:I would not fit the rotoflex couplings until the body if on unless your going to leave the rear suspension compressed. The high couple deflection angle for the time it takes for the rest of the car to be completed risks causing cracking and shortening the rotoflexes life
And I suspect it wouldn't do the wheel bearings a lot of good also.
My car was left up on jacks for a few months at a panel beaters whilst I sorted out the insurance/parts after a minor fender bender.
Interestingly, once back on the road, both rear sides had their bearings fail.
Within weeks of each other, and, ( as I keep good records), both well before their time.
Ralph.
- reb53
And for the future, to accurately check the condition of the doughnuts the car should be jacked up so that the doughnuts are in the fuly drooped position to reveal any cracks. I checked mine on my +2 and Sprint only yesterday as part of my annual self MoT check. Jim
- JimE
reb53 wrote:And I suspect it wouldn't do the wheel bearings a lot of good also.
Ralph.
I think you are probably spot on!
I read "somewhere" that one of the main reasons that Elans have limited rear wheel bearing life is the bearings are subject to a considerable side force created by the DoNuts.
Have you considered installing CV's whilst it is easy?
- vincereynard
Hi Tony,
i suggest as Rohan to install Rotoflex/Doughnuts when car is complet.
- alan.barker
