Drive shafts
PostPost by: Bahamayellow » Fri May 08, 2020 11:28 am
As you will have seen from my roll cage post I am slowly unpicking a number of the items stuck on the Elan Sprint I have. One thing I have debated for a while has been the driveshafts. At present the car currently has TTR solid driveshafts on and it drives nowhere nearly as smoothly as my Tatty S4 I had too many years ago with the Rotoflex couplings.
Has anyone converted back to Rotoflex or is the problem the same with a lot of rubber couplings these days in that the quality of the rubber is so poor that they're not worth fitting?
One item I did change which was a total revelation was the tyres Michelin XAS FF although expensive transformed the car in an instant.
Many thanks again,
1971 Lotus Elan Sprint
1963 1071 Cooper S
Bahamayellow
PostPost by: Mazzini » Fri May 08, 2020 11:49 am
Ha! I thought I was the only person to go from CV's back to Rotoflex couplings! I haven't driven the car yet, but I just wanted to put the car back to original specification.
PostPost by: lotusfan » Fri May 08, 2020 11:52 am
Just out of interest, what tyres did you have before and how old were they?
72 Sprint DHC
lotusfan
PostPost by: Bahamayellow » Fri May 08, 2020 12:35 pm
Mike I went through Uniroyals, Bridgstones and Goodyears all were new. The nearest I got were some cheap Chinese van tyres that Tony Thompson got me that he uses for his road Elan.
I took a deep intake of breath and vintage tyres knocked me 10% off at the Beaulieu auto jumble which made the whole thing more palatable.
1963 1071 Cooper S
Bahamayellow
PostPost by: 1owner69Elan » Fri May 08, 2020 2:28 pm
You refer to solid TTR driveshafts. These are not CV’s but rather u-jointed sliding spline units. AFAIK. TTR doesn’t sell CV’s. Tony T felt that CV’s are sub-standard compared to his units.
I can imagine these TTR shafts don’t drive all that smoothly for a road car and in non-smooth road conditions.
You might consider CV’s before going back to rotoflexes.
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: Bahamayellow » Fri May 08, 2020 3:45 pm
Hi 1owner69
Thanks that explains the harshness I had assumed they were all the same I might try Sue Miller in that case.
1963 1071 Cooper S
Bahamayellow
PostPost by: Grizzly » Fri May 08, 2020 3:53 pm
I agree with 1owner69Elan, i have kelvedon/shaft tec drive shafts and frankly they are much smoother than the Rotoflex's.
I wouldn't say the CV shafts are fit and forget but they aren't far off, i am a bit of a purist so was a little loathed to put CV shafts on but i found the Rotoflex joints don't like to be parked up for any time and they seem to be of sub standard quality compared to the 70/80's items.
In my opinion i consider the Cv shafts a reversible safety upgrade (just make sure they have quality cv boots on)
PostPost by: Davidb » Fri May 08, 2020 6:41 pm
I dunno. I have U jointed/sliding spline drive shafts and I don't notice any problem with not being able to drive smoothly. Mind you, I have never driven an Elan with donuts though. :roll:
Surely any other car would be the same-apart from a GT40 maybe...
'65 S2 4844
PostPost by: Bahamayellow » Fri May 08, 2020 10:29 pm
It’s not the smoothness of driving it’s the harshness of delivery but I did drive 2,000 miles across Spain and France and back home in the Sprint for our honeymoon 10 years ago. Guess I’m just getting old.
1963 1071 Cooper S
Bahamayellow
PostPost by: Andy8421 » Sat May 09, 2020 7:04 am
Many threads on this, but IMO, Rotoflex are just damn dangerous. The frame on my Sprint was mangled (I assume) by a PO and a flailing driveshaft. I am very glad I wasn't driving it when it did.
It always seems to be the diff end that goes - perhaps because it is hotter and oilier than the wheel end. The problem is that the driveshaft doesn't stop flailing until the car stops - or the driveshaft becomes wedged, locks the wheel and spins the car off the road.
CVs for me.
32 Standard 12
Various modern stuff
PostPost by: HCA » Sat May 09, 2020 7:46 am
I am no expert engineer, but I did pick up from someone wayback who was involved in the design of the original Mini, that UJs 'lost' their effictiveness when deflected more than 5 degrees off their rotational axis, but within the 5 degrees they are better than CVs in delivering power.
If this is the case, I am surprised TT designed his with UJs. Even on a well set up Elan, surely there are many times in a race where deflection will be quite pronounced, no?
Hal Adams
Evora SR
Elan +2
HCA
PostPost by: Concrete-crusher » Sat May 09, 2020 8:20 am
Just a comment I installed the TT driveshafts, new shocks and springs and all new bushes including diff mounts and I'd say the drive is very smooth. I previously fitted new doughnuts and they only lasted a few years before splits appeared, that said they never actually failed.
Concrete-crusher
PostPost by: rgh0 » Sat May 09, 2020 10:12 am
HCA wrote:I am no expert engineer, but I did pick up from someone wayback who was involved in the design of the original Mini, that UJs 'lost' their effictiveness when deflected more than 5 degrees off their rotational axis, but within the 5 degrees they are better than CVs in delivering power.
The TTR shafts use U/J as that is what the 26R used and what has to be used if into racing in Europe.
regards
PostPost by: Foxie » Sat May 09, 2020 12:21 pm
Andy8421 wrote:Many threads on this, but IMO, Rotoflex are just damn dangerous. The frame on my Sprint was mangled (I assume) by a PO and a flailing driveshaft. I am very glad I wasn't driving it when it did.
CVs for me.
I burst an outer rotoflex doing a racing start in the outside lane at traffic lights.
Swept the caliper clean of the strut.
Left me sitting there with a very red face ! :oops:
Changed to CVs after that.
68 Elan +2, 70 Elan +2s
PostPost by: miked » Sun May 10, 2020 6:03 am
Done thousands of miles in sliding spline UJ in both Elan's and Plus 2 and there is nothing wrong with them IMO. I value my backside as it is all rather close in an Elan.
As stated there is a lot written on here. Old rubber versus new etc. Even problems with poor grade CV shafts. Some not manifested themselves yet as owners not done enough miles.
:D
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
Next
