Aluminum prop shaft?
PostPost by: h20hamelan » Sat Jan 25, 2020 5:49 pm
Working on a T5 conversion for the +2, considering what needs to be done.
If I need to change the propellor shaft, would I not use aluminium. (Ford Aerostar fits my Volvos nicely)
https://www.dennysdriveshaft.com/c3_alu ... hafts.html
I am sure there are others, MG owners seem use these people.
Love your Mother
Earth
PostPost by: msd1107 » Sat Jan 25, 2020 11:09 pm
You can also get carbon fiber drive shafts. Circle track racers use them.
msd1107
PostPost by: h20hamelan » Sun Jan 26, 2020 1:22 am
The carbons are a bit more money, actually, about 4x more.
Pirated info
What's the Difference Between Carbon Fiber and Aluminum?
When it comes to building strong and light parts inexpensively, aluminum is a great choice. It’s an economic and stiff material that many performance parts are made of. With recent developments, however, more and more parts are being made out of an even lighter material: carbon fiber. While carbon fiber is lighter than aluminum, it’s also much more expensive.
Steel driveshafts are stock for noise and vibration dampening
Light weight alternatives “free up horsepower” by letting the engine rev faster
Aluminum driveshafts can drop about ten pounds from your “Lotus”
Aluminum driveshafts are significantly cheaper than their carbon cousins
Carbon fiber driveshafts are stronger than aluminum and produce less noise
Carbon fiber is also safer to run because when aluminum fails it shatters whereas carbon fiber shears
Love your Mother
Earth
PostPost by: 2cams70 » Sun Jan 26, 2020 6:37 am
I think some cars mainly use Aluminium driveshafts in order to change the natural frequency of vibration so that it occurs outside the operating speed range of the shaft for improved NVH.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: benymazz » Wed Aug 11, 2021 5:52 pm
Bumping this thread as I was thinking about having a custom aluminum driveshaft (propshaft) made for my S2, in the pursuit of adding lightness of course. Has anyone done it? I assume space could be a concern as I would guess an Al shaft will be a larger diameter but I think there should be enough room in the tunnel for it.
-Ben
1965 S2 26/4623
benymazz
PostPost by: h20hamelan » Thu Aug 12, 2021 12:10 am
I could measure one from an Aerostar, i am sure it will fit.
Love your Mother
Earth
PostPost by: bitsobrits » Fri Aug 13, 2021 1:11 am
While there is plenty of room in the tunnel itself for a larger diameter driveshaft, because the front flange of the differential is not centered along the tunnel centerline (it's offset a bit toward vehicle right) and therefore the driveshaft runs at a slight angle through the tunnel, you could run into interference with the rearmost bulkhead in the tunnel.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: h20hamelan » Fri Aug 13, 2021 1:43 am
Love your Mother
Earth
PostPost by: nmauduit » Fri Aug 13, 2021 8:32 am
h20hamelan wrote:wonder if carbon is the way forward
https://www.speedwaymotors.com/Carbon-F ... 71359.html
this certainly looks interesting, though I suppose they quote their minimum length U-joint (Spicer 1310) center to center: would their minimum length of 28" allow for accomodating an elan (4 speed gearbox)?
In any case, I would be interested in finding out the first hand experience of anyone having gone that route (carbon or alloy)
S4SE 36/8198
PostPost by: gherlt » Fri Aug 13, 2021 8:47 am
Me too. Looks very interesting
1964 S1 (in boxes)
1967 S3 DHC
1969 S4 FHC
gherlt
PostPost by: redhatman » Sat Aug 14, 2021 9:38 am
I have a new custom made steel propshaft from a cancelled project for a T5 gearbox to a Elan diff if interested,
Redhatman
redhatman
New-tral
PostPost by: gherlt » Sat Aug 14, 2021 10:48 am
I am interested more in the weight reduction than the strength.
1964 S1 (in boxes)
1967 S3 DHC
1969 S4 FHC
gherlt
PostPost by: h20hamelan » Sun Aug 15, 2021 4:58 am
redhatman wrote:I have a new custom made steel propshaft from a cancelled project for a T5 gearbox to a Elan diff if interested,
Redhatman
Question, what happened, did you have an extra driveshaft made? Or liked the 4speed better, speedo? Do tell more please!
Love your Mother
Earth
