Diff ratio - hill climbing - need higher revs on corner exit
I run my S1 GTS in a hill climb championship - the engine performs very well at 35000 rpm and above but out of a couple of corners my exit revs in second gear are lower than that - consequently the car takes a few moments to really get the power down.
At the moment I am running a 3.9 diff with Quaife ATB and a close ratio gearbox - does anyone have suggestions or experience with an alternative diff that would give me higher exit revs on slower corners?
David
David
- dunclentdr1
...good spot Rohan - boy it loves to rev but haven't got to 35000 yet - gets going above 3500, more so from 4000 prm.
David
David
- dunclentdr1
Yes, I?d agree, consider changing to a 4.1 or 4.4.
However, with these ratios you might find your unweighted inner rear having a tendency to spin up on exit of tight corners, so moving from an ATB to a properly set up plate LSD can make a very nice combination.
Having said that, I have no experience with my Elan the hills, but this was a combination in my hillclimb Caterham (4.1 and a low preloaded Titan LSD) and was a significant improvement over a 3.9 and a Quaife ATB.
There maybe other issues relating to this set up in an Elan, others with experience will be along to point out.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
If your exit speed in a corner is below 3500, why not just downshift before the corner?
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
...have tried that - it is a hairpin with very heavy breaking and a lot of steering input required so I'm busy and also dropping into first takes down my speed around the bend via the engine braking...
- dunclentdr1
I swapped the 3.55 diff for a 4.55 in my Plus 2 in April.
It's now just perfect for hillclimbs (I won the Irish Historic Championship last year, looking good again this year !) but on normal road driving I'm at 3.5K at around 60mph.
So now I'm thinking I need to swap out the 5-speed T9 with the 4.55 for a 6-speed with the 3.55 !
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
What class are you running? As you will know that will dictate any tyre change, for example Rohan?s choice Yoko 050 medium or soft are MSUK list 1c, so not eligible for roadgoing production (list 1a only) but otherwise ok in modified production / libra classes (dunno about historic classes), but would be out gunned there by other super soft hillclimb tyres (eg Avon or Kumho) or slicks.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
...road going hill climb class so need a tyre on list 1a or 1b.
Recommendations welcomed...
David
David
- dunclentdr1
What tyres are you presently using?
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
