Rotoflex in the cold??
PostPost by: nomad » Sun Nov 25, 2018 5:04 pm
Just curious but am wondering if Rotoflex donuts had a higher rate of failure in really cold weather. I would think they would have.
Kurt
26/3754
nomad
PostPost by: StressCraxx » Sun Nov 25, 2018 5:14 pm
It's a non issue. I have driven my elan in -8C weather when I lived in Colorado. I was uncomfortable until the heater warmed up, but my Elan took several long trips and some commutes without any issue at all.
StressCraxx
PostPost by: saildrive2001 » Fri Nov 30, 2018 8:35 pm
I used my Elan for four years when I came to Ontario, Canada & had no noticeable problems with the donuts in temp to -30C. I did have to block off the nose of the car almost completely to get the engine up to temp.
Keith Marshall
saildrive2001
PostPost by: nomad » Fri Dec 07, 2018 4:03 am
Well then if we could get a stainless steel chassis they would make a great modern winter car! :D
Kurt
nomad
PostPost by: saildrive2001 » Fri Dec 07, 2018 4:45 am
You can get a galvanized chassis, shouldn't rust. Narrow tyres are good in the snow & 50/50 weight distribution is also a bonus. I only ever got stuck once & that was when the snow was deeper than the ground clearance & the car was lifted up enough that I had no load on the wheels.
Keith Marshall
saildrive2001
PostPost by: Andy8421 » Fri Dec 07, 2018 6:35 am
nomad wrote:Just curious but am wondering if Rotoflex donuts had a higher rate of failure in really cold weather. I would think they would have.
Kurt
26/3754
The rotoflex warm up when they are running due to hysteresis in the rubber. I did read that the failure rate of the inboard coupling is higher than the outboard coupling - it was suggested that the inner coupling ran at a higher temperature because of the hot air from the rad / exhaust / engine that gets blown along the middle of the frame past the gearbox when the car is being driven.
As a result, it is possible that the rotoflex may have a lower rate of failure in cold weather.
32 Standard 12
Various modern stuff
Users browsing this forum: jebracing and 14 guests
