Stale donuts?
PostPost by: SENC » Mon Jan 22, 2018 5:33 pm
As my S4 was previously refreshed by my dad (about 20-25 years ago) and is in generally good shape, my intent has been to drive it and work on it as small things come up to learn about it and create a list/gather parts for a comprehensive, body off restoration in a few years (maybe kick it off when she turns 50?).
I had hoped to drive it down to see a TC specialist in a few weeks about. He is about 4 hours away, but I have another reason for the trip and since he is there I thought it might be good chance to meet and get his thoughts and observations. After looking at my donuts this weekend, I'm thinking that may not be advisable and that I may need to speed up my plans to replace with CVs before a full renovation - but I'm holding out irrational hope that the experts here tell me otherwise.
20180121_142047.jpg and
20180121_142019.jpg and
20180121_142039.jpg and
Henry
69 Elan S4
65 Seven S2
PostPost by: theelanman » Mon Jan 22, 2018 6:04 pm
Erm.......ive seen worse.....and in use.......
They don't look like they're separating from the metal so seem ok to me
theelanman
PostPost by: tvacc » Mon Jan 22, 2018 6:06 pm
Is that a full crack in one of them? They look pretty iffy to me. Lets let others chime in.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
72 Elan Sprint, 93 Caterham (Bought new), 05 Elise RD (Bought new),
99 Elise190, 05 Elise BLK (Bought nearly new), 2024 Emira, 2005 MiataSpeed Turbo
tvacc
PostPost by: theelanman » Mon Jan 22, 2018 6:10 pm
theelanman
PostPost by: alan.barker » Mon Jan 22, 2018 6:28 pm
I would think it is wiser to bring forward the fitting of CVs.
PostPost by: tvacc » Mon Jan 22, 2018 6:38 pm
What concerns me is the second picture. About 2 oclock. Is that a slit the entire width of the donut? Or is is just a shadow?
Tony Vaccaro
tvacc
PostPost by: david.g.chapman » Mon Jan 22, 2018 6:48 pm
Yes - picture 2 at 2 o'clock. I think that section needs to be checked carefully. It looks like a crack to me, and it depends how deep it is I suppose.
2-3mm deep OK for now but change soon, but any deeper change ASAP?
Dave Chapman.
david.g.chapman
PostPost by: john.p.clegg » Mon Jan 22, 2018 7:47 pm
+1 for the above,bin and go for the CV's or U/J's...
John :wink:
PostPost by: SENC » Mon Jan 22, 2018 11:24 pm
I wanted to check again thinking what several of you saw was exagerated by lighting and angle - I was right, but on changing my angle I spied one much worse - a through and through - so I'm definitely going to have to tackle the rear end before getting back on the road. So much for budgeting! I'll restart my reading on cv options, happy for any experience you may have with particular versions and how I might determine best value for my S4. Will also start my list of other things to do while dismantling pieces back there.
3 different angles on the previously unseen break.
20180122_181144.jpg and
20180122_181138.jpg and
20180122_181133.jpg and
Henry
69 Elan S4
65 Seven S2
PostPost by: webrest7 » Tue Jan 23, 2018 12:01 am
Have recently replaced mine with the Australian version manf. in here in Australia by Elantrikbits.
I agonised over spending the money but after evaluating all the options they really are the only way to go, all the other options seem to be a bit makeshift and have their drawbacks IMO.
During replacement it was noted that there had been previous failure and believe me it made a he'll of a mess so give those bloody donuts the flick and make the change.
The trikbits version is the premium way to go but if you don't think you can afford them anything is better than living with the threat of those rubber devils letting go on you.
The car drives so much nicer too as an added bonus.
Forget that malarcky about the traditional Elan windup being so pucka and the way they were designed.
The driving pleasure is only increased in the knowledge that one of those driveshafts aren't going to let go causing much damage and perhaps even more importantly threat to life and limb.
webrest7
First Gear
First Gear
PostPost by: Famous Frank » Tue Jan 23, 2018 12:43 am
Please don't be alarmed, just get a set of CV's and replace those horrible donuts asap. I wouldn't give those donuts to a starving policeman,
In 1970 I attended a SCCA ( Sports Car Club of America ) SOLO II event, sometimes called a Gymkana. There was a 67 Elan in attendance. One of the first I ever saw. Twenty seconds into the first run his right rear inner donut failed. The rear axle flayed around until he was able to stop. He was only going about 35 miles per hour. The Rear Lower Control Arm was bent, the axle tore a hole in the gas tank, and then then tore up some fiberglass.
I said to myself I'm never buying one of those cars!!!! I didn't buy one, I now have seven !!!
Check all the usual fine suppliers, buy a set, and install them. Best money ever spent !
Best of luck but don't drive on those donuts.
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank
PostPost by: StressCraxx » Tue Jan 23, 2018 1:04 am
SENC wrote:I wanted to check again thinking what several of you saw was exagerated by lighting and angle - I was right, but on changing my angle I spied one much worse - a through and through - so I'm definitely going to have to tackle the rear end before getting back on the road. So much for budgeting! I'll restart my reading on cv options, happy for any experience you may have with particular versions and how I might determine best value for my S4. Will also start my list of other things to do while dismantling pieces back there.
The attachment 20180122_181144.jpg is no longer available
The attachment 20180122_181138.jpg is no longer available
The attachment 20180122_181133.jpg is no longer available
Good catch. Contact JAE Parts, Dave Bean Engineering or RD Enterprises. They all sell the same well made kit to convert to CV Joints. The replacement donuts are of poor quality now.
Worth every penny.
http://www.jaeparts.com/
http://davebean.com/
http://www.rdent.com/
StressCraxx
PostPost by: mbell » Tue Jan 23, 2018 1:54 am
Worth every penny.
I have these on my plus two and think they are a very good option as they also replace the output shaft. This gives them increased length and reduced angles of deflection. While I am not certain but they may avoid the need to got travel limiter on an elan as needed but a lot of the other options.
They are the most expensive option, more than trickbits but you are getting new out put shaft too which are another common failure point.
PostPost by: JonB » Tue Jan 23, 2018 7:54 am
How is the rear disk attached with the Elantrikbits setup?
PostPost by: theelanman » Tue Jan 23, 2018 12:46 pm
ah.....they look like they need to be done asap.......
I looked at it on my phone and decided it was shadow and tiny surface cracks.......
now with those photos I can see its not...... :oops:
theelanman
Next
