elan differential 4 hole stub axle
Saw a posting on this forum of an image of a 4 hole stub axle for elan diff/english axle . ..........does anyone know what company produces that stub axle
[email protected]
[email protected]
- 69posi
Probably as a replacement axle for 26R which originally used Hooke type U joints. At least later 26R used crossed roller half shafts because Chapman was concerned about friction in normal splined shafts.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
My 1989 Westfield has a differential using a early escort english axle tranex lsd , it has this aluminum rear diff housing made by westfield which looks almost identical to elan , westfield built custom stub axles and fabricated a u joint setup for the axle driveshafts/ discontinued/ superseeded by sierra differential ........the splines ,I think are 22 teeth which tend to twist under high horsepower, I see this 4 hole flange type inner stub axle for elan ....are these available in 4340 chrome molly or better steel ???
I want to switch my setup from u joints to constant volocity shafts
any ideas ...leads ??
- 69posi
69posi wrote:Steve ....TTR ???......do you have a website for TTR and phone number for them
https://www.tonythompsonracing.co.uk
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
