CV's
bitten bullet and purchased a set of Kelvdon CV's.
nearing completion and a quick nosey at the donuts left me unsure of their condition so decided to swap out.
am i correct in thinking its a good time to change rear discs and pads?
also any tips for fitting without a lift set up?
looks like load is required on suspension from vids on internet so wondering if i can do this with car on axle stands under wishbone or Chapman strut?
any tips?
David
any tips?
David
- davidc
+ spread the load with a plank between Axle Stands and sill
- alan.barker
One lesson learned after installation,
with my old struts on the rear when the body is lifted, and the wheels allowed to droop unsupported (tire ship), the angle on the CVs would tear the boots when rotated.. so either don't do that, or restrict the droop with shorter struts or some sort of restraint.. I went thru several sets of boots before finding the issue..
- stovekjj
David
Make sure you mark the Diff end (if not marked by vendor) before you fit. I suspect they are new ?
This will ensure they always run in the same direction and bed in that way so if you ever remove them in the future they will be run in the correct rotation
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
