Gearbox and Diff Oil
Going to change the diff and Gbox oil out, been in a while. Does anyone have the codes for which Redline oils to use. Its just a normal road car with no track use, albeit with a set of QED 420 cams and 150ho. All help gratefully received.
thanks
thanks
Hi Mark, I recently changed the oil in our Elan.
I used MTL in the gearbox, and 75W90ns in the back axle.
RogerFrench - Fourth Gear
I retract the MT-90 as I did also use MTL.
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901 - Second Gear
CG901 wrote:I retract the MT-90 as I did also use MTL.
I used the normal redline MTL for the Lotus. Also have MT90 but for the daily.
For some reason I bought heavy duty redline diff oil. Which is a peptobismol pink, seems to work fine thou and have a very nice quiet diff.
- mbell
