Prop Shaft removal - in car
Hello all,
After experiencing pretty bad viabrition at 40mph + my thoughts lead to the propshaft being the culprit.
I have not yet checked the uj's and will do as a matter of corse, but as a general question, is it possible to remove the propshaft from a +2 in situ i.e. with body on, dif and engine and box in place? I am sure the workshop manual suggest this is possible but has any one ever tried it successfully.
Peter
Peter
1968 +2 BRM
- Peter +2
I have never done it personally but I have heard it can been done and seen comments posted here about that.
As i understand it you drop the shaft off the diff and pull it back to one side of the diff you can pull it out of the gear box tail shaft and drop it to the bottom of the tunnel. If you then remove the gear box mount and jack it up you can pull the shaft forward under and to the side of the gear box and out of the car.
Hopefully someone who has done it can confirm
I've removed a propshaft on an Elan S4 many years ago. A plus 2 should be the same.
Basically as Rohan describes. If I remember rightly the diff mounts all need to be undone and diff moved to one side /twisted as well as one driveshaft disconnected. I disconnected the nearside driveshaft, more space, the diff comes out this side?
Cheers Gray
Cheers Gray
- Gray
Can't remember exactly how I did it, but I did (had to change the rear Uj that failed). I have a Spyder chassis but don't see that a standard Lotus chassis will be materially different. I also have a standard 4 speed gearbox.
I know that I jacked the car onto axle stands at both ends so that I could crawl around underneath, removed the exhaust from the manifold back (I have a big bore exhaust with centre box on my Zetec engine), undid the bolts that secure the prop to the diff and then slid it out. Not fuss or dramas, or I would have remembered.
Peter
Peter
PeterK - Third Gear
I have never done it on a Elan Plus 2. But I have done it on an Elan. I actually got it down to about doing in 20 minutes.
On an Elan, you put a scissors jack under the bell housing. You remove the bottom brace under the tranny. you raise the tranny and bellhousing up until it is almost hitting the top of the tunnel.
You then remove the bolts that hold the propshaft to the diff. You then pull the propshaft out the front of the car.
I could do this in 20-25 minutes on the Elan.
tony V
tony V
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
72 Elan Sprint, 93 Caterham (Bought new), 05 Elise RD (Bought new),
99 Elise190, 05 Elise BLK (Bought nearly new), 2024 Emira, 2005 MiataSpeed Turbo
tvacc - Fourth Gear
Thank you all,
Your experiences and advice, gives me the inspiration to have a go. For some reason when I read the Workshop Manual, albeit some while ago, I thought it implied that the propshaft was removed from the rear. My fear was the WM had forgotten to say "remove the body shell first"!
Peter
Peter
1968 +2 BRM
- Peter +2
Peter
Don't forget to do a quick "write-up"
Please
Please
Hi All
Yes you can remove the prop shaft in a Plus two did it in April.
1.Drain Gear box
2.Disconnect 4 no flange bolts
3.Support gearbox to allow the removal of the mounting
4.Jack up gear box to allow clearance
5.Pull prop shaft to rear and position it so that it is as far back as you can get it, the shaft should then be free of the box
6.Raise the gearbox tail of the box to create a space to pull the shaft out between the tail shaft and the transmission tunnel entrance, a bit of fiddle but can be done, remove the shaft from below the gearbox tail.
7. to return the shaft use the access to the transmission tunnel next to the drivers seat.
I did this by jacking up the front of the car and supporting with axle stands but better if you have a lift
Good luck
1.Drain Gear box
Good luck
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
A recommendation: Place reference marks on the flanges at the differential so that you can return the flange "as it was" when you are done. May avoid balance or other issues on reassembly.
And even if you're as fast as Tony at R&R, replace both UJs while it's out. They're cheap.
- denicholls2
JH
Many thanks for the guidance, out of interest does your car have a Lotus chassis or Spyder and other than disconnecting the dif end UJ, did you have to disconnect the dif from the half shafts to give extra movement?
I will mark and replace both UJ's
Cheers both.
Peter
Cheers both.
Peter
1968 +2 BRM
- Peter +2
Peter
My car has the original Lotus chassis, there is no need to remove any of the diff tie rods or drive shafts.
Just make sure you get the diff flange as far back from the gear box as you can so that the splined section is out of the gearbox.
I think I had it lifted over the diff flange to gain as much movement as possible. Pulling the shaft out through the transmission tunnel is a fiddle but turn it till you have the space to pull the diff flange through, remember the orientation for when you replace it.
On replacement I fed the shaft back into place and then slipped a piece of wood under the splined shaft UJ to raise it to somewhere near the male spline, then went under the car to slide it into the gear box by reaching into the transmission tunnel.
Its not difficult and most will be obvious when you carry it out
+2s130 1971
+2s130 1971
