Aluminium welding repair, diff output.
PostPost by: Elseezed » Fri Jan 08, 2016 8:22 pm
Found this when checking diff after scraping off years of muck.
image.jpg and
Found no circlip and 3 blobs of Araldite repair.
image.jpg and
Repair by Shrigley Engineering.
Repaired by Andy at Shrigley Engineering here in Manchester. He also replaced the seals and checked diff and even filled with oil.
Les.
PostPost by: rgh0 » Sat Jan 09, 2016 12:01 am
Welding up and and re-machining the circlip area is certainly possible. Machining a ring and then welding the ring in place may be easier than building it totally by welding. I have seen both done
It also looks like a new diff output shaft has been made in two pieces and the arms end welded to the new plain shaft.
I tried that a couple of times many years ago but could never get them to last under racing stresses. The welds always eventually failed rapidly. Maybe they would last longer on a road car
PostPost by: Elseezed » Sat Jan 09, 2016 2:18 pm
Previous owners solution. It is for road use and worth checking along with the doughnuts once the car is In use.
Diff just refitted this morning, note diff o/p spider L.H; is assume original.
image.jpg and
Back in
Made a big difference refitting after grinding off casting at front of diff.
Les.
