Play in differential
PostPost by: seniorchristo » Fri Jun 19, 2015 1:22 am
I purchased a used 3.55 differential which seems to have excessive play in the internal gears. If the axles are held in place there is about 3/16"+ of radial movement at the circumference of the pinion flange. Does anyone know the specs for this or have an opinion?
Chris :)
67 Elan Super Safety
67 Elan +2
PostPost by: lotusjohn » Sat Jun 20, 2015 7:24 pm
The spec is .005 - .007" at the crown wheel with pinion not moving. You probably have some internal issues.
lotusjohn
New-tral
PostPost by: rgh0 » Sat Jun 20, 2015 11:25 pm
That spec is backlash on the crown wheel to pinion teeth. if you hold the output shafts with the diff assembled you also have the backlash in the spider gears of the differential which have substantially more clearance. I dont think 3/16 of an inch at the circumference of the input shaft is excessive.
PostPost by: seniorchristo » Sat Jun 20, 2015 11:55 pm
Thanks again! You are a wealth of Lotus information! Both of my diffs have around that same amount of play.
Chris :)
67 Elan +2
PostPost by: Hawksfield » Sun Jun 21, 2015 6:45 pm
I would concur with Rohan as I had my propshaft off recently and that is around the back lash I had at the drive flange.
+2s130 1971
PostPost by: vernon.taylor » Mon Jun 22, 2015 5:53 am
Salut
It sounded normal to me, too - but I diidn't dare answer ! Nice to know why - thanks, Rohan.
Vernon
vernon.taylor
