Solid half shaft
PostPost by: Type28 » Tue Dec 09, 2014 3:42 pm
Please see the attached picture. The metal spacer block on the solid half shaft on my car is cracked straight through. Any idea who?s shafts these are and why it would crack? - going to take it off for a better look.
George
Type28
PostPost by: el-saturn » Tue Dec 09, 2014 4:06 pm
..... TBO i'd say you can leave it where it is: IT CAN'T GO NOWHERE and the ring still fulfills its purpose! i guess others will agree! sandy 36/4982
PostPost by: elansprint » Tue Dec 09, 2014 4:19 pm
George they look like Mick Miller CV jointed shafts I may have one would need to search though
Ian
elansprint
PostPost by: peterexpart » Tue Dec 09, 2014 5:33 pm
If those are on an Elan (Not a Plus 2) have they been fitted with a Drop Restrictor ?? If not it could be that someone has jacked the car up and then rotated the wheel, the aluminium part that has cracked is part of the CV Ball retainer, just my suggestion !!
PeterExpart
New Forest National Park
Hampshire UK
peterexpart
PostPost by: Type28 » Tue Dec 09, 2014 9:06 pm
The shafts are on an Elan - what do the drop restrictors look like? I take it they prevent full travel?- if it's part of a bearing carrier it will no doubt need to be replaced. Has anyone experienced this before?- if you click on the picture you see the whole picture.
George
Type28
PostPost by: rgh0 » Tue Dec 09, 2014 10:23 pm
The crack looks to have developed where the stud is screwed into the adaptor plate, or is it a recessed head bolt of some sort fitted to the plate? In any event that is the thinnest and most heavily load part of the plate. Is the plate Aluminium or steel I have seen both used.
It would guess it could have cracked just because of misalignment between the stud and the diff drive shaft hole as these were not precisely tolerance by Lotus as the Donuts did not require a precise hole location but the adaptors do. You often need to ream the holes to get acceptable fit of the adaptor bolts
I would replace the cracked adaptor plate and check the fit of the others
