What Diff Oil for +2?
PostPost by: 8bit-ash » Sat Nov 15, 2014 12:10 pm
Hi, I've tried to search for the answer to this but don't seem to have found an answer other than the recommended Redline. I need to get the diff back in this weekend so thats a no go as I can't get it locally. I've got 75w90 Semi Synthetic MT5 Halfords gear oil. Will this do the trick? I know theres talk of MT5 not being any good for brass but is this relevant to the diff?
1970 Porsche 911E Sporto
2002 Porsche Boxster S
2004 Audi A2 TDI 90
8bit-ash
New-tral
PostPost by: john.p.clegg » Sat Nov 15, 2014 2:58 pm
There's not a lot special about the ford diff and little brass in it (plugs ?)
Gear oil is good....at least for now until someone has something " special"
John :wink:
PostPost by: 8bit-ash » Sat Nov 15, 2014 4:49 pm
Cheers. thats what I figured so I bunged it in and swore abit before the diff nicely slipped back into position.
2004 Audi A2 TDI 90
8bit-ash
New-tral
PostPost by: rgh0 » Sat Nov 15, 2014 10:02 pm
As long as its a GL5 spec gear oil then you should be OK
PostPost by: elansprint71 » Sat Nov 15, 2014 10:22 pm
I know that the diff on the +0 Elan can be a bit of a bugger to fill when it is in the car (no idea about the +2) but I guess it's the same :oops:
Now that you have got it back together and have a bit of time... I looked at what the racing Elan boys did and cut out a hole in the boot which not only gave access to the diff plug it also allowed access to the hand-brake tree.
There are photos of this somewhere on the site but I'm jiggered if I can find them using the "search" function. :(
It turns a two hour job into 20 minutes and does not involve raising the car.
PostPost by: ericbushby » Sun Nov 16, 2014 11:21 pm
I fitted an inspection hatch in the boot to top up the diff oil. Be careful where you cut. It is low down near the eath screw but measure carefully.
I used a boat 4" inspection hatch from marinesceneuk. About ?5.50 on ebay. I can now remove the plug and see the oil level with a torch.
Eric in Burnley
1967 S3SE DHC
I just noticed that this was a Plus 2 thread and I shouldn't be here. Sorreee !!!.
PostPost by: JJDraper » Tue Nov 25, 2014 10:34 am
I used another of the rubber bungs used in the transmission tunnel and a hole cut as in the picture.
Jeremy
Boot Area lo res.jpg and
