mick miller drive shafts
PostPost by: Mark plus 2 cabby » Tue Sep 23, 2014 8:45 am
hi ,
i have just bought a used set of these , does anyone know if theres are specific way to fit ?
are they handed ? , does it matter which way round re inboard outboard cv's ?
thanks
mark
Mark plus 2 cabby
New-tral
PostPost by: jono » Tue Sep 23, 2014 8:51 am
Mark,
If I recall correctly, mine were marked with a marker pen on the diff side as "Diff". Other than that I just followed a logical process and they are still brilliant after 2k miles.
Any questions or uncertainties though I would speak to Sue.
Jon
PostPost by: PeterK » Tue Sep 23, 2014 9:47 am
On some sets, the threads were not quite long enough on the inboard (diff side) studs, and if washers aren't used under the Nylocs, there is a risk that the nuts reach torque setting before actually clamping to the diff output shafts correctly,
PeterK
PostPost by: Chris » Tue Sep 23, 2014 1:40 pm
The studs on the outboard end are usually longer, as the have the added thickness of the disc to contend with.
PostPost by: Mark plus 2 cabby » Tue Sep 23, 2014 7:31 pm
Thanks to all for the help ,
particularly Chris , the different stud length is obvious, when you think about it
Thanks again
Mark plus 2 cabby
New-tral
PostPost by: steve.thomas » Wed Sep 24, 2014 4:30 pm
steve.thomas
PostPost by: au-yt » Fri Sep 26, 2014 8:59 pm
I would suggest using a reduce hex all metal nut like
3/8" 24 UNF 12 POINT NUTS AIRCRAFT/RACING NAS1805-6L
or some K nuts like these
http://k-nuts.com/index.php/products/im ... on-unifie/
nut_test2b.jpg and
Much better clearance and are reusable
20140618_205745.jpg and
20140618_205850.jpg and
Graeme
LOTUS Evora 400
Ginetta G27 S2
66 one-off 2.6Ltr v8 Mid-engine Berlinetta Coupe........... in restoration
..................................................Age doesn't matter unless you are a cheese................................................
au-yt
PostPost by: fasterbyelan » Mon Oct 13, 2014 9:54 am
I would not recommend reusing K-Nuts, it's a no no in motor sport. Their locking ability is significantly reduced.
Karl 8)
1970 S4 FHC SE
fasterbyelan
