TTR driveshafts - do I need reduced droop shocks too?
I am planning to have some TTR driveshafts fitted to my Plus 2 and have been quoted a price that includes reduced drop shock absorbers - I have read somewhere that these aren't required on a Plus 2 - can someone please advise?
I have a pair of Spyder semi-solid shafts also - do these need non-standard shocks?
David
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
1965 S2
1966 S3
- dunclentdr
David,
As far as I am aware, on a Plus 2 you do have to reduce the drop. That it was what the instructions which accompanied my TTR drive-shafts said and that is what id did on my Plus 2.
There several ways to reduce the drop but the simplest and probably the more expensive solution is to use TTR/Koni shocks which are manufactured with the reduced drop as you know.
That what i did.
Peter
That what i did.
Peter
1968 +2 BRM
- Peter +2
On my sprint (which has shorter wishbones) I ended up switching from TTR to Sue Millers cvs.
I use the car on the road and for the occasional hills and sprints and two solutions were offered - use limiting dampers (or a wishbone limiter) or stiffer roll bar.
I decided that whilst not perfect, I preferred more travel offered by a CV solution hence the change.
Gavin
Gavin
gav - Fourth Gear
I have just completed fitting my set of Mick Miller CV's (bought them 10 years ago) on the +2 and on full droop they did not completely lock up but as I turned the wheel checking there was definitely a very tight spot that took a bit to turn the wheel so I would say they are right on the limit. When raised just half an inch the wheel turned freely.
I figured that after 25 years I have never seen the car on three wheels and not a gutsy driver, or race the car anyway so doubt the car would ever see full droop. General opinion though from others responses was no one had had any issues and were impressed.
I posted in the Elan discussion section too requesting information on the longevity of them and seeking general opinions on the ride quality but for some reason the post was moved to the drivetrain section for repairs and maintenance so not sure what that had to do with a discussion on the NVH performance of a solid driveshaft
Plus 2 - Second Gear
