In house research: flex donut coupling improvements
• Page 1 of 5 • 1, 2, 3, 4, 5
All,
Just though I'd share...When in doubt DIY...I recently completed a prototype flex donut for the elan drivetrain in tough polyurethane. Hopefully soon, will road test a set of them. Unfortunately, with my elan still in restoration, it will be some time before actual road testing. The donut prototype has improved reinforcement and superior material properties (improved elongation, peel strength, weathering, etc) as compared to the traditional rubber material used in various flex donuts (many inferior) on the market. The material chosen is very resilient, tenacious and tough which should withstand constant flexing and stresses. After looking at my original recommended oem heavy duty donuts, the design addresses common failure points and should greatly reduce the disadvantage of rubber degradation by atmosphere, chemical attack, temp cycling, etc. I've always been intrigued by improvements through the use of new materials and techniques especially to improve upon issues with material quality, longevity, driveability, etc. My goal is to see if I can maintain the dampening effects in the elan driveline, reducing vibration, harshness, wind up and prove a much longer service life than those available today. Will let you know how it progresses...
David D
1969 Lotus Elan S3 Coupe
Sent from my iPad
David D
Sent from my iPad
- lotustastic
Dave,
I wish you well with the project, I only went to CV joints because of the rotoflex problems, and feel sure I and many other users would revert to rotoflex if a good product was available
I am a retired mechanical engineer, and spent most of my working life in mining mineral processing and chemical industries. One of my colleagues had problems with a rubber covered component from a grinding/milling device. He replaced the component with one covered in polyurethane and had great success. Unfortunately that initial success was never repeated. All subsequent versions failed at the bond between steel and polyurethane. Hopefully technology has advanced since then and you will be successful.
Richard Hawkins
Richard Hawkins
- RichardHawkins
Interestingly, I just did some maintenance on a marine drive system. It had these mounted. Maybe some of it will be useful to you. Sorry for the picture quality, cell phone snaps before everything was reinstalled and inaccessible again.
Will
Will
-Will
26/5175
26/5175
- ensign42
David,
Good luck with your project, I'm sure should you crack the rotoflex problem you'll have a real winner.
Ian
Ian
- silverlink
David
If your car is not on the road how are you testing your couplings. Is the 'In House' part of your title a clue?
Like many others I hope your product is a success.
Out of interest is this a coupling that looks something like the rubber one we know and love (moulded on to inserts) or is it a totally different construction with maybe 6 separate polyurethane elements?
Ian
Ian
Elanman99 - Third Gear
David,
I think many of us are interested. I was considering the rubber drive couplings used by BMW for the driveshafts. There was a discussion about them last year. I am considering buying one and seeing if it can be engineered for our cars.
David
I too wish you success with your experiments.
You said "My goal is to see if I can maintain the dampening effects in the elan driveline, reducing vibration, harshness, wind up and prove a much longer service life than those available today." I believe this will be key to your testing, as many people forget how much the Elan was praised for it's ride back in the 1960s, the doughnuts playing a not insignificant part in that.
The other aspect that I think to be important is that the finished product be black, to appear as near as possible like the original item. None of this shiny blue poly-what-not stuff beloved of Scooby drivers!
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
If they work I'll have a set in Dayglow Yellow if that's all that's available...
Thanks for all of the comments and support...The donuts have bonded bolt bosses and reinforcements and will be circular. After reviewing the failure points on my own hd donuts, they appeared to fail/break clean often at the bolt bosses over time. My hope is that the redesign fixes this for longevity in addition to reducing the overall material breakdown from the elements. The current donut is in natural color (white). Colorant can be added. Once I work through some more of the molding/commercial design issues, I can post pics. I work in polymers daily and am drawing on this experience to hopefully have a winner.
- lotustastic
Miles Wilkins of Fiberglass Services has a shed load of brand new donut couplings....
- Spidersprint
I'll be giving him a call next week
'72 Sprint
'72 Sprint
- richardcox_lotus
