Cv driveshaft installation help needed
Hi all
After having purchased new cv driveshafts,I have this morning tried to install one side.
Having got the 3 studs located in the diff end,at the hub end the studs are to long to allow them to go through the holes and there doesn't seem to be enough play to manoeuvre the studs through the holes.
Do I need to release the a frames from the chassis to allow the hub to swing out?
Shafts were purchased from Kelvedon and the studs are loctited in
- thorbs000
Hello Thorbs,
I might not be able to help but I am interested to see the job. I want to do the same mod. someday.
I will send you details in a private message. Please contact me.
Eric in Burnley
1967 S3SE Type 45
Eric in Burnley
1967 S3SE Type 45
- ericbushby
The CV joints should telescope in a little, but if that isn't enough why not undo the lower swivels on the hub carrier so that you can swing it out slightly. Then it should line up.
TroonSprint - Fourth Gear
THough this topic is about doughnuts (rotoflexes) rather than solid shafts, it shows with photos the technique of fitting the rear drive shafts by undoing the bottom links at the rear hub.
lotus-gearbox-f37/replacing-the-doughnuts-t16456.html?hilit=doughnuts
Maybe if you fitted the outside (longer studs ) first then the diff?
