prop shaft for a 5 speed gearbox
PostPost by: whaig » Tue Oct 22, 2013 7:49 pm
I am fitting a 5 speed box in my plus 2, but still need propshaft, can anyone assist, do you have one or do know where I can get one?
whaig
New-tral
PostPost by: RichardHawkins » Wed Oct 23, 2013 7:08 pm
I suggest you try Bailey Morris. I have not used them but have spoken with Clive Cox where they had a stand at an old car show. Clive seems very knowledgable and helpful. I intend to use Bailey Morris when I get round to my 5 speed installation.
Richard Hawkins
RichardHawkins
PostPost by: whaig » Thu Oct 24, 2013 6:51 pm
Thanks, it looks as if that is the way to go... if they are manufacturing one, would they have the dimension? I don't
whaig
New-tral
PostPost by: whaig » Fri Oct 25, 2013 12:04 pm
Checking the history, it appears that the prop shaft for a 5 speed + 2 is 39.5 inches to middle of each CV joint, getting closer :-)
can anyone provide the diameter of the flange at both ends? Thanks
whaig
New-tral
PostPost by: rgh0 » Fri Oct 25, 2013 12:12 pm
I have a spare 5 speed shaft I can dig out and measure up. I will do it this Sunday if you don't get the details from anyone else.
PostPost by: whaig » Fri Oct 25, 2013 6:57 pm
Thanks Rohan, much appreciated
whaig
New-tral
PostPost by: rgh0 » Sun Oct 27, 2013 11:23 pm
Measured up my spare 5 speed prop shaft and attached a few photos for reference.
Shaft Overall length between the UJ centres
sliding spline fully compressed = 972 mm / 38.3 inches
fully extended = 1016 mm / 40.0 inches
splined section travel = 44mm / 1.73 inches
End flanged section length from centre of UJ = 30mm / 1.18 inches
Flange bolt pitch circle = 2.75 inch ( this is a non metric dimension)
(you may want to check your diff flange as I think early Elans at least used a smaller pitch circle).
flange bolt hole = 5/16 inch ( this is a non metric hole!)
same for front and rear flanges
I did not pull out the UJ,s but they appear to be the same as on the 4 speed prop shaft
5 speed prop shaft front end.jpg and
5 speed prop shaft.jpg and
5 speed prop shaft rear end.jpg and
PostPost by: 5496RW » Fri Mar 09, 2018 9:26 am
Great information and pictures.
I will match the one that is tagged for sale, lets see if it matches the propshaft that is tagged as an Elan +2.
Many many thanks. steve
5496RW
New-tral
PostPost by: mikealdren » Fri Mar 09, 2018 9:31 am
Rohan beat me to it......
mikealdren
PostPost by: ericbushby » Fri Mar 09, 2018 9:39 am
What`s going on here.?
Is It Me ?
Why does there seem to be a 5 year difference between the early and recent posts ?
Eric in Burnley
PostPost by: john.p.clegg » Fri Mar 09, 2018 9:49 am
Doesn't time fly when you're enjoying yourself..
John :wink:
PostPost by: john.p.clegg » Fri Mar 09, 2018 9:51 am
P.S.
I can only see 2 propshafts on Fleabay , both of which are for the 4 speed gearbox ?
John :wink:
PostPost by: gjz30075 » Fri Mar 09, 2018 10:05 am
Linking back to the original thread, just started
lotus-gearbox-f37/1974-elan-plus-propshaft-length-t41410.html
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: ericbushby » Fri Mar 09, 2018 10:09 am
Is that what is known as cross threading !!
Eric
