Differential filler plug replacement.
Hello all,
Before I post in the wanted section, is there any where I can purchase a differential filler plug? The hex head on mine is pretty much circular in shape as I discovered this afternoon! I suppose I could cut a slot in it and fit a flat head screw driver in it but I'd like to explore the replacement avenue first.
Pete
Pete
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
- Bombay Racing Green
If you mean the level plug on the back of the diff case SJ Sportscars list it.
http://www.sjsportscars.co.uk/index.php?mod=10
S4 DHC
S4 DHC
- oldelanman
I don't think you can cut a slot in it anyway; the level plug on the back is hollow, I think, for lightness and I presume the one on the top of the diff is hollow also.
Best way of getting at it is to take out the spare wheel and use a 2 to 3 inch circular hole-saw to make a large neat hole in the front side of the boot. But before you do so get a suitable blind grommet to fill the hole or make a disk of aluminium which you can screw with self-tappers onto the front wall.
Thanks Roger and Bill. Looks like it alright.
Yes, I had noticed it was hollow but wasn't sure how far it went. Thankfully a previous owner had cut a neat hole in the boot and used a rubber plug to tidy it up as well as seal the hole.
Thank you for the help.
Pete
Pete
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
Great Bill, true "blue sky" thinking!
I'll nip around to the plumber's merchant's in the morning.
Pete
Pete
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
billwill wrote:Best way of getting at it is to take out the spare wheel and use a 2 to 3 inch circular hole-saw to make a large neat hole in the front side of the boot. But before you do so get a suitable blind grommet to fill the hole or make a disk of aluminium which you can screw with self-tappers onto the front wall.
What a great idea !!
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
englishmaninwales wrote:billwill wrote:Best way of getting at it is to take out the spare wheel and use a 2 to 3 inch circular hole-saw to make a large neat hole in the front side of the boot. But before you do so get a suitable blind grommet to fill the hole or make a disk of aluminium which you can screw with self-tappers onto the front wall.
Not novel to me I think I read it on this forum long ago, before I did it to mine.
Is there really a need to do this? I checked my diff level last weekend.. Just jacked up the rear left. Did'nt even take the wheel off.. An hour max...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
I suspect checking is relatively straightforward, but.topping up without getting it everywhere might not be?
- robertverhey
A small hole - just large enough to pass a piece of 1/2" hose (cut from my garden hose ) - makes topping up easy and a std blanking grommet will block it. The hardest part is deciding on the exact spot to drill the hole so it lines up with the filler plug.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
robertverhey wrote:I suspect checking is relatively straightforward, but.topping up without getting it everywhere might not be?
I used a 12" piece of tubing attached to the oil bottle... Not too bad.
Billwill was taking about a 2-3" hole...
Phil Harrison
Just back from the plumber's merchant's. Indeed, AHM, it is a 1/2 BSP plug with an 18 mm hex head. The drain was an 8mm plug apparently. Two of each and fibre washers, ?6.
Thanks for the help.
Pete
Pete
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
