uj play
That loose diff securing bolt can result in a mysterious clicking noise.
It took me ages to find that out.
UJs should not have play in them as far as I am aware, it possibly indicates that the roller bearings have thinned down. Possibly lack of lubrication.
The U/J's look to be the same as those on the propshaft and kits are widely available to replace them for around ?10 each from the usual suspects or ebay. The kit includes cups, rollers, spider and circlips and the procedure to replace them is covered in the workshop manual under Final Drive. Provided that the holes in the yokes are not damaged and the sliding spline is not worn that would be a much cheaper option than changing to CV shafts.
Your diff mount bolts may just have worked loose, before you go buying new mounts try just torqueing them up.
S4 DHC
S4 DHC
- oldelanman
Yes, just tighten the Diff bolts. You need two people one to do the nut in the boot and another underneath with all your socket set extension pieces clipped into each other.
Or you can do it on your own with a mole wrench in the boot.
Changing a whole UJ is relatively easy as oldelanman has said. Modern ones are greased-for-life, I think. They are a light-interference fit (i.e tap with a small hammer) and held in by circlips.
Salut Friedy
I picked up a set of driveshafts like yours - old-style Spyder, I think. Mine have some play in the sliding spines which I hope will diminish once packed with grease.
So check carefully - the play you feel might be the sliding spine or even the diff.
Vernon
Vernon
vernon.taylor - Fourth Gear
