inner bearings final drive
PostPost by: tvacc » Sat Jul 06, 2013 12:34 am
I am having a hecl of a time putting the new bearings on to the fina drive. I have pulled the final drive and cleaned it all up, I still connot get the inner bearings on to the shaft that "gears" to the final drive.
Ant help appreciate it.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
72 Elan Sprint, 93 Caterham (Bought new), 05 Elise RD (Bought new),
99 Elise190, 05 Elise BLK (Bought nearly new), 2024 Emira, 2005 MiataSpeed Turbo
tvacc
PostPost by: tvacc » Sat Jul 06, 2013 12:41 am
I have put the final drive inboard shafts into the freezer. The bearings go on right to the point where you have to put the circlip on, but no further.
Tony Vaccaro
tvacc
PostPost by: robertverhey » Sat Jul 06, 2013 2:09 am
Might need a press? Designed to be a tight fit I think......
robertverhey
PostPost by: tvacc » Sat Jul 06, 2013 3:01 am
tvacc wrote:I have put the final drive inboard shafts into the freezer. The bearings go on right to the point where you have to put the circlip on, but no further.
Cannot go any further. Hits the end. Just enough room for the bearing and circlip. I put the shafts in the freezer, put the bearings in the oven at 200.
Almost got it on. But had nothing the diameter of the inner race and enough depth to bang it down. Went on about 1/4 of an inch.
Tony Vaccaro
tvacc
PostPost by: john.p.clegg » Sat Jul 06, 2013 5:44 am
What brand of bearings are you using?
John :wink:
PostPost by: rgh0 » Sat Jul 06, 2013 7:45 am
If the shaft is to the correct tolerance and the bearing from a reputable brand to the correct tolerance then you should be able to press the bearing on with it and the shaft at ambient temperatures. Easier if the shaft cooled and bearing heated but still possible if not.
Ideally you have a suitable length of pipe to bear on the inner race of the bearing and a press. A suitable bearing splitter and puller from the other side is also an option. A hammer or a large vice on a length of pipe is also possible. A suitable rod of about 1/4 inch diameter or flat end punch can be used also to drive the inner race on by carefully tapping around the periphery of the inner race.
What ever method you choose always support the shaft in the centre to avoid bending the arms
